metal noise?
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
metal noise?
okay on the way home at night i was driving my car and noticed a new noise that i am not fond of... it sounds like metal clanging together, and when i turn off the engine, it kinda does it crazy then stops, i havent had the chance to look at it yet but i will post what i find when i do, a friend told me its the timing chain, but wouldnt that make my car not run at all? the funny thing is.. is that i noticed that the car was being a little bit faster too, i have a 5.0 tpi... any, i mean ANY ideas on what it could be would really help me out.. thanks
-Blair
oh yeah, if i have the foot off the gas, and give it a little bit of gas then let go, it clangs pretty bad, then goes back to its normal every other second or so clanging..
-Blair
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
i had a 72 monte carlo that had a similar thing happen the gear on the cam was pretty much half way gone but it gave kind of a clang noise almost like a rod knock but higher pitched and when you rev the engine it would go with the revs when i changed it out i also ended up replacing the timing cover because it wore a hole in it
i drove it home about 25 miles with it like this ..
got lucky
got lucky
Car: 88 Corvette
Engine: 400, AFR heads, ZZ9, SuperRam, 730
Transmission: Slushbox
My 85 5.0 felt noticeably stronger the day before my timing chain spun off the sprocket completely. I figure it must have skipped a tooth and advanced or retarded the cam.
Didn't make any noise though - except when it failed completely and the pistons banged into the valves.
Car: 1985 IROC
Axle/Gears: no idea
it does it while its runing, and the noise sounds kinda random.
so this is a pretty serious problem? sweet...
yeah i would have it checked for sure i wouldnt doubt that it is the timing chain gear but we cant be certain without being there in person
Car: 1985 IROC
Axle/Gears: no idea
*laugh* i finally got around to looking at it, its the harmonic balancer, it came loose, 50 bucks at autozone and voila, no problems..
what was it doing ???
comming apart??
comming apart??
Car: 1985 IROC
Axle/Gears: no idea
it just sits there free, spins when the car is on, moves foward and back while spinning, im not too sure as to what it looked liek before it wenb bad but it still has the timing mark on it and everything, all i guess i can say to that is that its loose
MrPackstin
Oct 25, 2017 08:09 PM
bigjay89gta
Oct 15, 2015 08:04 AM
sjorgens
Oct 1, 2015 07:54 PM
