TPI or Crossfire Injection
Old Sep 19, 2004 | 01:51 AM
turbo_jimi's Avatar
Car: 85 Z28 & 86 TA
Engine: 350 Crate Motor & 305 TPI
Transmission: 5-speed & 700R4
Axle/Gears: 3.23 Open End & 3.27 posi
Bought an 85Z w/ an LG4...says on the bumper that it has "Crossfire Injection" but under the hood, doesn't look like what I've seen before and I also read that CFI was discontinued in '84 model year....please advise.
Thanks.
Old Sep 19, 2004 | 02:03 AM
nick418's Avatar
Engine: L98, Hemi 6.2
actually crossfire injection was made in 82-83 Fbodys , the latest CFI was in the 84 Corvette. Also are you sure its a 85? Check your VIN number and your RPO codes here, it would answer your questions. Or Maybe someone stuck it on there or maybe a swap...
https://www.thirdgen.org/newdesign/vin/
https://www.thirdgen.org/cgi-bin/rpo/index
Old Sep 19, 2004 | 02:09 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The bumper could have been changed out just as easily.
Look on the side of the car, on the GFX. It should say Z-28. If it's a crossfire car, it should say Cross-fire injection below the Z28. ALso, you could look up front, by the hood latch assembly, there should be a little plaque thing with the LU5 RPO. That's where mine is and I have a CFI car, well, was a CFI.
Old Sep 19, 2004 | 06:42 PM
maroguy1's Avatar
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
lg4= 305 4bbl carb
toronto formula
Nov 10, 2015 06:17 AM
z28addict8490
Sep 5, 2015 03:56 PM
3tas4me
Sep 4, 2015 01:45 PM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Aug 6, 2015 09:03 AM
