vacum port/lost my mind?
Old Sep 20, 2004 | 05:21 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
Ok, so I swapped the engine out of my 88 formy350, and into my 87 gta. It went well and everything seems to be hooked up right. All the vacum lines I have are in there place. So I do one last look around and see this port on the back of the plenum on the driver side with no hose to it. I look around and do not see a hose for it. Any Ideas what hose is suppose to go on it? I'm loseing/lost my mind trying to figure this out. Oh, the books I have do not show that port, just like the sticker on the hood. Thanks for the help.
Laters,
Conrad
Old Sep 20, 2004 | 05:29 PM
wackytower's Avatar
Car: 1985 Trans Am
Engine: Superramed 406
Axle/Gears: 10 bolt 3:73
To the fuel pressure regulator? or to the line that operates the flaps in in the heater controls?
Old Sep 20, 2004 | 07:35 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
The only port I can think of on the driver's side of the plenum is the one for the brake booster. It's all the way at the back corner and kind of angled.
Old Sep 20, 2004 | 08:22 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That be correct!!!!!!!!!!!!!!!
Old Sep 21, 2004 | 09:38 AM
twobirds's Avatar
Car: 1987 GTA 350
The brake booster .
Thanks guys,
Conrad
Old Sep 22, 2004 | 11:49 AM
Maverick_82's Avatar
Car: '82 trans am (w/ t-top)
Engine: 5.0L 305 H
Transmission: automatic
twobirds, consider yourself lucky. When I bought my 82 TA I found that when the 305 engine was swaped with a 350 all the vacuum lines for the emissions had been removed, the hoses were cut short and had screws acting as corks. If anyone has any answers or better yet diagrams, i'll get back to you with the models of the parts.
grngryoutmyway
Oct 18, 2016 05:48 PM
tmellott89
Oct 14, 2015 02:06 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
R13_Braz
Sep 18, 2015 05:00 PM
