Stuttering problems
Old Sep 21, 2004 | 10:13 PM
AlbertaFbody's Avatar
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
Stuttering problems
ok so i did some searching and found nothing my buddys 91 z with 305 5 speed TPI is running like hell. it runs like it is a 454 with a lumpy cam in other words its runing like its missing and stuttering alot. he says that it is ok after around 3 grand RPM. we changed the cap rotor and plug wires and plugs no luck. i have searched and came up with it could be the coil or the IAC sensor which i have no idea where it is. please help.
thanks ahead of time
Old Sep 21, 2004 | 10:40 PM
Car: 86 z28
so we took it for a spin and came up with its missing due to he has a header leak on one cylinder and you can hear that its missing. also thre is a bad gas smell and a little backfiring he has an electronic coil checked the connections and their all good.
Old Sep 24, 2004 | 10:57 AM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
Check for intake leaks. Put a vacuum guage on it to find out for sure.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
