My TB coolant bypass job
Old Sep 22, 2004 | 12:28 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
I wanted the smaller elbow fitting, but this is all I could create. Im not a licensed plumber, but oh well.
Big version (smaller quality picture attached in case I run out of bandwidth or server down).
Fits nice (but barely, its almost right up on the TPS). Only problem is that it started to leak where the fittings screw in in the elbow. Some thread sealant seemed to fix that. Hopefully this setup will survive 195+ degrees.
Old Sep 22, 2004 | 01:40 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Why didn't you just run a single hose instead of running one to the pipe fitting and the one out?
Old Sep 22, 2004 | 08:26 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Because a thick hose doesnt bend that much. Cant find one that is molded to bend the way it should (s shaped)
Old Sep 22, 2004 | 08:38 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Why not use an 'L' connector on the manifold to avoid that bend? Or re-route the hose so that that bend is no longer needed as such.
Old Sep 22, 2004 | 08:46 AM
bobsroc's Avatar
Car: 1987 IROCZ
Here is a pic that shows how I routed my single hose.
Old Sep 22, 2004 | 10:47 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Been driving with the hose laying on the alternator fan like t hat?
Old Sep 22, 2004 | 10:52 AM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
Thats not bad. The guy at autozone let me go back and look through all the pre-bent hoses and even take them outside to my car till I found one that fit really well. But good job dude.
Old Sep 22, 2004 | 11:46 AM
bobsroc's Avatar
Car: 1987 IROCZ
Pro, it has been like that for years, it is nowhere close to the altenator blades, it rests on the bracket. NBD..
Old Sep 22, 2004 | 12:00 PM
Andy 91GTA's Avatar
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
Pro. Why don't you use an L shape hose? I bought a Goodyear hose. I just had to cut it a bit and it fits perfectly.
Old Sep 22, 2004 | 12:43 PM
Drew's Avatar
Why make the hose turn 180*?
I went the easy route, I pulled the nipple out of the intake and plugged the hole. Then I removed the plug from the top of the waterpump and installed the nipple. One hose runs from the water pump to the heater core just like GM would have run it had they not had the coolant in the throttle body to begin with.
Old Sep 22, 2004 | 02:49 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
transporter, I went to autozone and found some hoses shaped like a question mark. Might work, well see when I get home from work.
Old Sep 22, 2004 | 06:29 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
omg lol i just found out that my car has the TB bi pass done to it already... lol must be the last owner did it... cause mine looks identical tot he one witht he single hose...
Old Sep 22, 2004 | 08:08 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Well I found a hose at autozone. Attached is a pic of the hose installed (leak free) and the part number for it. Its off like a toyota or something, but fits perfect.
Old Sep 23, 2004 | 08:23 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
good find
sometimes it just takes a little looking and hunting to find the one that will work ....not necessarily the factory but it works nicely ......
Old Sep 23, 2004 | 11:40 AM
bobsroc's Avatar
Car: 1987 IROCZ
Excellent, looks alot nicer Pro!! Good job finding that hose, it will surely help someone else.
Old Sep 23, 2004 | 12:16 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Maybe this could be a sticky, or the bypass article could be updated? Would make it easier to just go and get the hose and be done with it for most people.
Wish I knew what hose this went on though (for those that dont have an autozone nearby).:shrug:
$750 L98
Feb 1, 2025 02:25 PM
sheachopper
Jul 31, 2019 11:27 AM
