5.7 swap...
5.7 swap...
A guy I know is putting a '87 5.7 TPI motor in a'89 IROC 5-speed car, was originally a 5.0 TPI.
What is invovled? I assume he must use the harness from the 5.7 car, but it was an automatic.
What other changes must be made?
Assuming his car is already TPI he doesn't have to do much. As mentioned above he needs the knock sensor for a 350. He also needs 22lb. fuel injectors and a new PROM. Since his car is a 5-speed he will need to have someone burn a PROM for him, as no F-body had a 350 with a 5-speed. This is pretty simple actually. I did this swap, and I simply had a friend do it who had PROM burning equipment. The blank chip cost me about $5 bucks, and my buddy's labor cost me a Philly cheesesteak.
Car: '99 HO Z28 / '03 Trailblazer
Nevermind - I found my answer in another thread:
Originally posted by Trans Am#5
You shouldn't have any problems running the auto program with your T5 other than a service engine soon light indicating trans problems.
The car will run with an auto chip, but the ECM will be confused becasue it will be looking for input to see what gear the trans is in. Normally the ECM has the ability to alter idle speed in an automatic car based on what gear it's in. It's hard to explain, and I don't totally understand how it works myself, but since your ECM will be confused you might have a surging problem at times. I have seen the effects of this myself. It will run much better with a manual chip.
cool, thanks guys, anybody know where there's a place to burn the prom?
As far as no 5.7 cars built with 5-speed, yes there were some up here in Canada. They were used in the Players Challenge racing series, they were all 5.7 with manual trans. There might even be a part# for that prom????
I saw quite a few back in 87-90 I beleive it was....
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
PM me about burning a simple chip for you with the correct injectors constants, etc. I take if you want to keep the MAF setup, right? That'd probably be easiest, a lot less wiring than converting to SD/MAP.
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
I also did this swap and its still on blocks. I have a 350 with a T-5 bolted up, so what you guys are saying is it won't run properly? If i need a chip then guess I better start now before the car is done! PM me if you have access to one of these chips. thanks a ton.
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Originally posted by DuronClocker
I would think he could use his stock harness just with a different knock sensor (one for a 350 block)..
Kevin
Car: 1997 Corvette
Sensor on the block. If you have a 350, use the 350 knock module. Don't use a 305 knock module on a 350 because you can get false knock readings.
By the way, I just mixed up a quick BIN for a T-5 behind a 350 motor with stock iron heads. 83BlackBeauty is probably going to be the test mule for it.
Car: 1997 Corvette
Let me know if you're interested. Its got basically most of the stock calibration stuff from a 350TPI BIN just thrown into a 305 T-5 BIN, and I changed some of the highway mode settings to get a bit better gas mileage at semi-highway driving (constant 40mph+ etc) and changed some fan settings to 203on/195off. Shift light should come on at 4700-4800RPM or so (don't remember the exact setting right now). This is for stock 22# injectors, and that can be easily changed from one chip to the next. Like I told 83BlackBeauty, I'd recommend buying the MEMCAL adapter from Craig Moates' site to make things MUCH easier to install and eliminate possible issues.
I'll burn the chips for people if they need it, but I am not going to offer any performance tuning. Honestly, I think its pointless to tune a car over the internet/phone/etc, and I'm not good enough to be able to even touch that stuff if I'm not in person. All of the stuff I changed is pretty basic and should give you a good base for a stock 350TPI motor with a T-5.
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Car: 1997 Corvette
Yeah, I could do it and it'd be much cheaper. But like I said, its not going to be a performance chip. Its just a stock chip that will make your stuff work with some minor changes (fan controls, etc.). I don't want to mess with tuning anything over the internet. I have nowhere near the skills to do that and I think the only way to get a real tune is to do it yourself or take it somewhere. Problem is, those take time and more money. Depends what route you wanna go for I guess.
KO1
16
Oct 15, 2015 05:00 PM
bigjay89gta
Oct 15, 2015 08:04 AM
LT1Formula
Oct 8, 2015 08:34 PM
