Rocker Suggestion?
Old Oct 1, 2004 | 09:11 PM
vwdave's Avatar
Rocker Suggestion?
I am thinking of installing 1.6 Roller Rockers on my L98 the same time I do my valvesprings. I am just having trouble choosing a brand.
Comp Cams Pro Magnum $325
Crane Golds $320
Summit's (Looks exactly like golds, cept blue) $279
The main issue is durability. I have heard bad things about aluminum rockers cracking and such. I have also heard that it is because people spin the engine too high.
So far, I am kinda leaning towards the Pro-Magnums. Thoughts?
(I am running a LT4 cam and Comp 981 springs on stock iron L98 heads.)
Old Oct 1, 2004 | 10:05 PM
ljnowell's Avatar
Due to the properties of aluminum, all aluminum rockers will fatigue, and eventually fail. It is simply the nature of the beast. Personally, I use steel roller tip rockers for a street engine, but a lot of people use the aluminum.
Old Oct 1, 2004 | 10:52 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I agree with LJ. Aluminum seems to have a lower fatigue resistance than steel.
For a budget, I would go with Comp Magnums. If you can toss the change, both Crower and Comp offer steel full rollers.
Old Oct 2, 2004 | 02:52 PM
Edmond's Avatar
Car: 88' Corvette, 94' Camry XLE, 83' Z28
If you used synthetic oil, would that drop the temps enough to use the aluminum rockers? I did read that the Summit ones are heat treated. I was also told that the Summit brand ones are made either by Comp or Crane. They're just repackaged by Summit to sell. You're getting the same product for less because of the lack of "brand name."
Old Oct 2, 2004 | 03:00 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Heat doesn't kill the rockers. Stress does. Oil temperatures have no imput over the stress that a rocker arm undergoes.
Old Oct 2, 2004 | 06:48 PM
ljnowell's Avatar
As said above, aluminum has a fatigue factor. It will flex, and eventually crack. Its just how they are.
Old Oct 3, 2004 | 07:24 PM
25THRSS's Avatar
pro mags without question
Old Oct 3, 2004 | 07:27 PM
vwdave's Avatar
Supposedly, there is a centerbolt version out now.
Does anyone know what kind of improvement I will see with it? I have a mild bolt-on L98.
Old Oct 3, 2004 | 07:38 PM
25THRSS's Avatar
There has always been a centerbolt version. The self aligning rockers for 88 up heads were only available for centerbolt heads, therfor the self aligning pro mags for 88 up heads were made specifically for centerbolt heads.
Old Oct 3, 2004 | 07:39 PM
vwdave's Avatar
Hmph, I always heard that you had to modify the valve covers slightly to get them to fit.
Old Oct 3, 2004 | 07:43 PM
25THRSS's Avatar
you do in most cases, but it is very easy. This is a good thing though, as the width of the trunion enables larger needle bearings to spread the load.
Old Oct 3, 2004 | 07:47 PM
vwdave's Avatar
Yeah, you had to bend some pieces. There is a link around here somewhere...
Old Oct 4, 2004 | 09:14 AM
Edmond's Avatar
Or it's an excuse to just get a nice new shiny pair that the 1.6's will fit underneath.
Old Oct 4, 2004 | 09:21 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
dont you have to slot the pushrod holes to run 1.6 rr on the L98 heads? or am I mistaken?
Old Oct 17, 2004 | 06:52 PM
25THRSS's Avatar
If you are still interested, I am selling a set of brand new comp pro mag roller rockers. PM me if you are interested.
Old Oct 17, 2004 | 07:56 PM
FIREBIRD7777's Avatar
good post,, I allso over looked these rockers,, the pro magnums becuase in the catalog i never saw centerbolt style and nerver heard anyone else talk about them. They make a 1.6 steel version roller rocker for 88 and up ,, there is no guestion on what rocker im getting now
Old Oct 17, 2004 | 08:01 PM
vwdave's Avatar
Glad to help.
Old Oct 20, 2004 | 09:28 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I am useing the magnums ( not pro ) . But I went for the 1.52 ratio. In a book by David Visard .....he found these rockers to be 80% stronger than stock . I figured they would be all I need . and I am runnngi the SDPC 1007 springs ...good for .570 lift. 350 lbs'@ 1.2 "and 120 lbs at 1.8 . I too am useing the stock heads ( APR studed )
Old Nov 6, 2004 | 08:12 PM
vwdave's Avatar
The springs were a HUGE help. Turns out, at 1.700" the old ones were at 80lbs. I also had someone shatter my rear hatch, so I just now got the money to do the rockers.
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
ericjon262
Sep 11, 2015 06:07 PM
