took apart cant get back together HELP
Old Oct 4, 2004 | 01:13 AM
Incoming's Avatar
Car: 1986 Firebird T/A Streetracer
Engine: V8 350TPI
Transmission: Modified 700R4
Alright.... was going to take off my runners to polish them... figured itd be easy to get them off... everything was going fine untill i noticed there was a bolt i couldnt get to unless i removed valve covers... so i pulle off my alternator, and since i wanted to remove my smog pump i took that out... and the item that it was attached too.... is it important or not? i think it runs to the cat converter for some kinda of polution control garbage.. there are no emisssions test down here so i really dont care... do i need the item below???
the a/c compressor is on its own belt... when i tear that out what do i do with the line that goes to the radiator from the compressor?
thnx westley
Incoming's Avatar
Engine: V8 350TPI
opps forgot pic
Old Oct 4, 2004 | 10:59 AM
Morley's Avatar
That is the PEDEs valve, you don't need it if you are doing away with the air pump and related plumbing.
Old Oct 5, 2004 | 09:22 AM
Incoming's Avatar
Engine: V8 350TPI
Old Oct 5, 2004 | 09:42 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
are you removing it permantly? Or simply moving it out of the way?
Keep in mind the A/C system is under pressure, or, at least, it should be.....
If you don't want it, just follow the lines and detach them from wherever they hook up, and pull 'em out.
If you want to keep it, leave the lines attached, and just set the compressor out of the way.
Old Oct 5, 2004 | 10:55 AM
Incoming's Avatar
Engine: V8 350TPI
if i remove this will i loose alot of engine power? cuase ive been looking at engine pics and alost of u still have it on the car... i want a clean engine compartment and i want to remove all the thats under the hood... i can take out all of the pipes that attach to the smog pump and the PEDEs valve i can just follow the lines and unhook them out of the engine?
Old Oct 5, 2004 | 11:28 AM
Morley's Avatar
The PEDE's valve hooks to your exhaust manifolds and cat converter. You'll need to cap off the air tubes on the manifolds and the one going to the converter. And no, you won't loose power by removing it.
Old Oct 6, 2004 | 09:54 AM
Incoming's Avatar
Engine: V8 350TPI
perfectly answers my question im ripping my cat off it a few weeks anyways :rockon:
and
Old Oct 6, 2004 | 09:57 AM
Incoming's Avatar
Engine: V8 350TPI
do you have a link for a delete pulley for a 1986 firebird... i need to order one but all the pulleys ive seen are 88 and up i thought i had v belt but looking closer i realized the belt did turn other things... so set me a link and ill be cruzin
Old Oct 6, 2004 | 10:18 AM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
I may be wrong, but I think the delete pulley is for serpentine belt cars that wish to retain the use of the stock-sized belt. Not sure if you can do the same on a v-belt car. You may just have to measure and try them out at the auto parts store.
Old Oct 6, 2004 | 11:19 AM
Incoming's Avatar
Engine: V8 350TPI
i was mistaken about the vbelt.. i do need a delete pulley.. just need to know wher they sell them for my car and why the hell is my alternator on the left and compressor on the right every one elses is opposite of mine...
Old Oct 6, 2004 | 11:57 AM
DURTYBIRD's Avatar
... why the hell is my alternator on the left and compressor on the right every one elses is opposite of mine...
Can't help ya on where they sell them, but I can assure you my car has the alternator on the left and A/C compressor on the right. Its not V-belt, but its also got two different belts for the accessories.
Car was originally an LG4 car (now a 350 block)
Fronzizzle
Mar 18, 2019 08:29 PM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 21, 2015 07:20 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
