Difference between 85-88 and 89-92 TPI throttle cables
Old Oct 10, 2004 | 02:19 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, one of the last parts I need for my TPI retrofit this coming week is a throttle cable. I'm using this cable on a 2nd gen with a 327 in it. Year One shows two different throttle cables for the TPI 3rd gens -- one for 85-88, another for 89-92. Whats the deal with this? 89 was still a MAF setup, so I am not sure why it would be set up for a different cable. Can anyone suggest which I should use, and will it have the same fitting on the firewall / gas pedal end that the 2nd gen uses? Thanks
Old Oct 10, 2004 | 02:33 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Match it to the Throttle Body you are using...yes, '89 was MAF, but used the same TB as the SD TPI's.
Old Oct 10, 2004 | 02:41 PM
Car: 2000 BMW M5
8Mike, thanks, that's exactly what I needed to know. I almost bought an 89 throttle cable on ebay the other day. Good thing I lost the auction, since I have an 86 intake and throttle body!
9192camaro
16
Feb 3, 2019 12:21 AM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
