Going from TBI to TPI, help!!!
Old Oct 11, 2004 | 08:10 PM
Slowmaro91RS's Avatar
Car: 91 Camaro RS
Axle/Gears: 10 bolt posi/3.23
I have a 305 TBI that just blew a head gasket and i really don't see the point in fixing it since I plan on going bigger anyway so my question is how hard would it be to put a TPI setup on a crate 350 H.O.? I know the TPI conversion rerally isn't that hard but putting it on an engine that's set up for a carburater kind of confuses me. If anyone has any info for me please let me know. Thanks.
Old Oct 11, 2004 | 11:34 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
It's really not that hard........biggest thing is it is very time consuming. IMO the hardest thing actually was changing the fuel pump over,that was about a 5 hour job w/ a bay lift. Best advise i can give you is find a donor car with the TPI the same year or as close to the year of your car that you can. I was always having to go back for parts (relays,wiring components,cables...etc...) That way it helps keeps the cost down from going to the dealership buying new parts. Get a book on TPI swaps,sumitt sells a few that really helped me out alot and read up on it,plus this site has a mountain of info on it that helped a ton too. I think i probably spent a total of 40 to 50 hours in total doing the swap (mind you i am not Mr. Goodwrench). Luckily not by design i took my set up off of a car that was close in age to my car so i didn't end up with alot of wiring issues. I guess the 3 most valuable words of advise i can really give you is..1)patience 2)patience and 3)patience.
Old Oct 11, 2004 | 11:48 PM
Car: 91 Camaro RS
Thanks, I figured it was extremely time consuming so I know what I'm getting myself into. I'm not at all worried about the fuel pump or anything like that (I've done quite a few fuel pumps on F bodies). The main part I'm worried about is finding a good crate 350 to put the TPI on. I don't have the money for an aftermarket setup especially on top of having to buy a new engine so price is also an issue.
Old Oct 13, 2004 | 09:16 PM
Car: 92'Camaro RS
Engine: a loud one
What are you looking to spend on the engine? What kinda price are looking at for the TPI set up?
Old Oct 13, 2004 | 11:29 PM
Car: 91 Camaro RS
I don't really have any set prices. I'm just looking to do this as cheap as possible without losing any performance. I can get the TPI setup easilly, I'm just looking for a crate engine it'll bolt up to. I'm not sure what all would need to be changed.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
