Random hesitation
Old Oct 18, 2004 | 09:08 PM
Phyte's Avatar
Car: 92 Z28
Engine: 350tpi
Random hesitation
Every once in a while my engine will hesitate at a stoplight. It's even hesitated and died twice. The faster you take off the harder it hesitates. Do TPI's dump extra fuel in like a carb does when you take off? It's random so I'm not sure where to start.
Phyte
Old Oct 18, 2004 | 09:18 PM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
check your TPS voltage. More times than not, hesitation while driving is a TPS problem. It should be around 0.54VDC +/- 0.07VDC. If that is not the culprit, you definitely need a tuneup; plugs, wires, cap, rotor, and possibly 02 sensor. Hope that helps.
Old Oct 18, 2004 | 09:23 PM
Phyte's Avatar
Car: 92 Z28
Engine: 350tpi
I'll check that. I just put in a new set of plugs and wires because it was missing. The next thing I was going to replace was the O2 sensor.
Phyte
Old Oct 19, 2004 | 01:39 PM
Camaro Project's Avatar
Car: Chevy
Engine: Largest Factory V6 on Earth
Transmission: 700R4 w/ Trans Cooler
Don't forget the fuel and air filters.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
ndndndnd
Sep 28, 2015 08:00 AM
