305 heads off what's worth doing?
Old Oct 21, 2004 | 10:23 AM
FocusGhia's Avatar
Car: 88 Camaro IROC T-Top - Gunmetal Grey
Engine: 305 TPI V8
The car is smoking on startup and using a bit of coolant.
I'm assuming it's the head gaskets.
So I'm getting them replaced in January which I figure gives me time to order (cos I'm in the UK) a couple of bits and pieces to drop in at the same time.
What's worth doing at the same time???
I can't afford to buy new heads by the time I've added shipping and I can't go to a breakers yard and pull bits off a corvette, this is the UK and these cars don't hardly exist over here!
Cam or rockers perhaps? They're fairly light to ship.
The car is an 88 305 TPI Auto with 2.72 posi rear end
mods: Transo shift kit with Corvette servo, Performance Resource PROM, ported plenum, descreen maf, high flow air filters, tb airfoil, fuel pressure bumped to 47psi.
I'm planning on changing the rear end gears to 3.43 posi
Suggestions?
Old Oct 21, 2004 | 12:44 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
lots of folks on here have had excellent results porting their stock head castings. do a search for some posts by sitting bull, i think he has had fantastic results with stock heads. so order a head porting kit from summit for $40 and go to town. the smoke on startup is not head gaskets, it is worn valve seals which are an easy fix as long as the valve guides arent worn out too bad. your machine shop can resurface the heads and recut the valve seats once your porting is done.
also since you have the 305 TPI with the 2.73 rear, you may have the peanut cam. a cam swap could help you a lot, and some roller rockers wouldnt hurt either.
many guys on here with ported stock iron heads, better cam, headers, and a decent rear gear (3.23 or better) are running 13s in the 1/4 mile.
Old Oct 22, 2004 | 04:29 AM
FocusGhia's Avatar
Engine: 305 TPI V8
What cam should I go for?
I thought the 88's had roller cams in them?
So if I get the heads ported and the rockers and cam replaced which should I buy?
I'll go for 3.43 gearing.
Also, should I switch to a different stall converter?
Old Oct 26, 2004 | 03:07 PM
FocusGhia's Avatar
Engine: 305 TPI V8
Anyone?
Also, I could fit some Corvette aluminium heads.
In which case which cam should I go for then and should I be changing the runners and base if I have those heads?
Old Oct 26, 2004 | 03:39 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
the topic of cam selecion has come up a million times on here just do a search. my cam specs are listed in my sig and i have stock intake runners and base and i am running the aluminum heads.
Old Oct 26, 2004 | 04:47 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
If you go to the Comp Cam website you can look in there online catalogue and they have a number of cams that are for TPI'ed motors. They list what cam is best for what application, such as stall or aftermarket chip etc. Try there. Or try a search on these boards.
Old Oct 27, 2004 | 12:19 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
If you have the heads off put on headers, always a good investment and easy to do with the heads off. I also agree with a pocket port and new cam.
Old Oct 27, 2004 | 12:42 PM
FocusGhia's Avatar
Engine: 305 TPI V8
Thanks Warbird and Speed88.
i'll take a look at the Comp Cams website and ensure I get the headers done at the same time (they were planned anyways) to save a few $$$.
1MeanZ, I DID do a search (as always) if I had found a definitive answer I wouldn't be asking the question. Oh and your sig ain't showing on that post.
Old Oct 27, 2004 | 04:12 PM
Damon's Avatar
2 things I never miss a chance to do to a stock head if I happen to have it off the engine anyway.....
1. New valve guide seals. If you get little oil smoke puffs on startup and when hitting the gas quick this is probably why.
2. Upgrade the valve springs. Even if you're using a stock cam chances are you springs are worn out originals anyway. If you're using a more performance oriented cam then dropping in some Crane 99848 springs in place of the stock units can be done very easily without machine work. They're true bolt-ins and are significantly stiffer than stock and will control a mild performance cam MUCH better at higher RPMs. If you have a more serious cam then there's absolutely no substitue for putting in the recommended springs, even if it requires machine work.
I also like to have the guides machined down by about .100". Haven't met a stock GM head yet that couldn't stand to have the retainer-to-guide clearance opened up to be safe. Most stock heads have interference around .470" valve lift. My machining down the guides by .100 you are safe up to levels you'll never actually lift the valve unless you're nuts (.570"+)
Old Oct 28, 2004 | 05:37 AM
FocusGhia's Avatar
Engine: 305 TPI V8
Damon, that was EXACTLY the info I was after.
Thanks very much for taking the time to reply.
I am getting smoke on startup hence the heads are getting the valve guides replaced.
I'm also getitng some coolant loss which I am hoping is down to the head gasket (no visible smoke on acceleration so it can't be too serious).
I will buy the springs and give them to the shop to use when they rebuild.
I'll also enquire with them as to the cost of getting the machining done.
Thanks again!
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
