MAF to Speed Density ??
Old Oct 21, 2004 | 09:22 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Hey guys
I was wondering If you could take an existing MAF TPI
and exchange it with a Speed density TPI with proper ECU
and harness??
SD TPI doesnt require a sensor in front of the throttle
body .. which goes good with my plans for the car.
and from what I hear .. performs well in altitude.
What about performance? which is easily susseptible
to modifcations?
Thanks for the advice
Old Oct 21, 2004 | 09:53 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Its totally possible and if you are handy with a laptop, infinitely more tuneable than a maf car. I plan on doing this same swap in the near future. But I am taking everything off a 91-92 car and having it powder coated and what not before its all installed
Will
Old Oct 21, 2004 | 10:56 PM
LnealZ28's Avatar
Car: 1987 Z28
Engine: 383 Single Plane EFI-NOW RUNNING!
Axle/Gears: Not there yet...
Here's all you need to know: http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
I've done the swap myself on my '87 and it ain't that bad, you just need to triple check your work. You can do it!
Old Oct 21, 2004 | 11:15 PM
TPI's Avatar
You guys are waaayyy to generous with your
work and knowledge.
Thank the heavens :hail:
Where do you find the Eprom tuner program for the laptop?
and does a NEC 133mhz Pentium qualify?? :shrug:
Old Oct 22, 2004 | 12:33 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
work and knowledge.
I use a Gateway P166MMX. The MMX instructions shouldn't matter much for this task, and the 166 vs. 133 shouldn't matter a whole lot either. I've heard of people running this stuff on a 286. (well, the datalogging stuff). TunerPro works great on this laptop as well. I'm running Win98 SE with 128MB RAM and a 6gb hard drive.
Old Oct 22, 2004 | 01:41 AM
norcalz28's Avatar
Where can I get a hold of these programs? such as tunerpro???
Will
Old Oct 22, 2004 | 02:05 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
? I don't know if I agree with that. I've worked on and tuned both. And I know a LOT of very fast MAF cars. Probably the most difficult thing to tune on a MAF car is the MAF Scalar tables...but that's only for part throttle and/or idle. In WOT, people tend to adjust the fuel by the PE tables...so the myth that your can't adjust the MAF system for high HP applications when you exceed 255 g/sec is, well, just that...a myth.
Yes, SD has a "cleaner" intake but it isn't the big restriction that people think. In fact, I still haven't seen anyone produce any quatitative data on a very high HP application to show that the MAF system is noticeably underperforming a SD setup. And then, the question would always be...was the tune 'optimal' on both setups.
After working and playing with both, about the best reason I have seen for converting to SD is, you need a new MAF or MAF ECM and it's cheaper to install a SD ECM. But if you have a perfectly good working MAF system, I would stick with it.
Old Oct 26, 2004 | 07:58 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
maf is easier to tune, don't believe the hype
Old Oct 26, 2004 | 11:42 PM
norcalz28's Avatar
Can you guys help me. I want a basic tune. Nothing fancy, but I feel with free(er) flowing exhaust and the few mods I have that the car could benefit from a tune. PLEASE HELP ME!!!! I am in dire need on info how to do it myself. Thanks
Willl
Old Oct 26, 2004 | 11:52 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
DIY PROM-board read the stickys, should be a good start...
/N.
BumpaD82
Feb 26, 2016 02:57 PM
Nick McCardle
Sep 10, 2015 08:36 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
