how high can the hsr afpr be adjusted to?
Old Oct 24, 2004 | 05:21 AM
big black bird's Avatar
Car: 1989 transam
Engine: 350 hsr trickflow twisted wedge g2 comp cam 490 lift haltech e6gm ,33lbs bosch injectors
Transmission: t700
just completed the swap and fired the car up i seem to only be able to get only 40 psi from my afpr. by turning the nut clockwise it raises the pressure ?i have turned the nut as far as goes ive heard of people being able to raise it to 60psi could anything be wrong with the regulator the pressure gauge that i am using is a liquid filled one permanetly mouted on the fuel rail
Old Oct 24, 2004 | 10:44 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Are you removing the vacum line off the regulator when you are adjusting the pressure?
Old Oct 24, 2004 | 05:57 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Holley AFPRs are notorius for having problems. Most people who have a HSR have had at leats one problem with it if you bought the whole kit and cabodle from Holley. As above though, disconnect the line and try doing it with the engine off and pump priming.
Old Oct 25, 2004 | 04:40 AM
Car: 1989 transam
Transmission: t700
yes the vacume line is disconnected tested it today it seems to be working ok i got it as high as 55psi with vacume line disconnected definately have to lower the psi pulled out a plug it was pitch black
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
86CamaroDan
Sep 29, 2015 10:08 PM
SG91camaro
Sep 5, 2015 10:27 PM
355tpipickup
Sep 4, 2015 05:32 PM
