Making Custom Runners
Old Oct 28, 2004 | 07:52 PM
klumb15's Avatar
My machine shop teacher was telling me today when he was a kid he heard of guys making custom TPI intake runners...he said they would take them and hollow them all out and then weld metal on the gaps, makign them look much like the SLP, i believe, the siamesed ones...have you guys heard of this at all??? do you think it can be done?? and what kind of gain do you think i'll see if I do this, and will it mess up my computer because the airflow is different???
Old Oct 28, 2004 | 09:19 PM
Abubaca's Avatar
A few guys have done it.
There are pics here on TGO, but heck if I know where.
Do a search for "runners"
Old Oct 29, 2004 | 08:50 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Do a for "Runner glue"
Old Oct 29, 2004 | 04:33 PM
klumb15's Avatar
okay i did a search, found some stuff, but i still dont' really understand....my idea was to just completely hollw the inside out, so each 2 tubes are totally connected and the inside would actually be a big oval...i think this would allow tons of air to get in there...i just want to know will this f*ck up my computer and the way it runs???
Old Oct 29, 2004 | 09:30 PM
91banditt2's Avatar
Engine: 5.7 HSR
it wont do anything to your ECM but it will affect the way the motor will run.if that's the only modifcation that you do you may have a lean condiction,which is bad mmm-k.if your adding more air you should allso add more fuel like maybe a set of 24lbs injectors.but if you do that you should also change the injector constant in the programming
really in a perfect world you should change your programming any time you make a major change (heads,cam,intake,headers,gears,larger injectors....).that way your ECM is making the correct adjustments and your motor is running at it's best.
also would you be putting these runners ona set of stock heads?just because your intake flows a massive amount of air doesn't mean that your heads will.
wrap you mind around that
Old Oct 30, 2004 | 12:24 AM
klumb15's Avatar
yea i know..but you have to start somewhere...it was just an idea...i can prolly pick up a cheap set of runners, and see how it works, then if it doesnt, oh well i won't be out too much money...i got other things to worry about this winter besides major engine mods...
Old Oct 30, 2004 | 07:53 PM
turbotater's Avatar
http://sethirdgen.org/personal/siameesedrunner.jpg
these are my runners
Old Oct 31, 2004 | 03:59 PM
klumb15's Avatar
thats exactly what my idea was..what kind of power gains did you see with that??
Old Oct 31, 2004 | 09:52 PM
91banditt2's Avatar
Engine: 5.7 HSR
i have an extra set of runners sitting around that i cut up to siameese.but i desided to go a different route with my car.
Old Oct 31, 2004 | 09:57 PM
91banditt2's Avatar
Engine: 5.7 HSR
here is a pic of one of them
Old Oct 31, 2004 | 10:01 PM
klumb15's Avatar
you wanna sell them or what???you can actually knock out the metal on the bases of the flanges too right???so its like 1 big tube throughout??
Old Oct 31, 2004 | 10:03 PM
91banditt2's Avatar
Engine: 5.7 HSR
here is another set that i used to have,sold these to another member here.
Old Oct 31, 2004 | 10:11 PM
klumb15's Avatar
that looks nice...can't you connect the the 4 holes and make 2 oval shapped holes???you would get more flow that way wouldn't you? then port the pleanum to match??
Old Nov 3, 2004 | 12:57 AM
91RamAir Formula's Avatar
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
here is a pic of my AS&M semi siemese runners.
Old Nov 3, 2004 | 11:06 AM
megaracerx's Avatar
wow....does that add any real performance??
Old Nov 3, 2004 | 03:53 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Well correct me if im wrong but wouldent that shorten the effective runner length down to just the length of the base manifold giving a good increase in rpm potential
Old Nov 4, 2004 | 09:50 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
And then I sold them to another member here, and never looked back at TPI.
--Joe
Old Nov 4, 2004 | 09:51 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yep, increases plenum area and shortens runner length. Result is less velocity, but more potential for RPM.
This is of course, after you spent a weekend hogging out an aftermarket base.
-- Joe
Old Nov 4, 2004 | 10:26 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
This is what the AS&M runners are worth on a stock 89 Vette with headers. This was the non-siamesed version. The siamesed versions will probably sacrifice a little down low, but give larger gains up top.
https://www.thirdgen.org/techbb2/att...postid=1750460
Old Nov 4, 2004 | 12:22 PM
91banditt2's Avatar
Engine: 5.7 HSR
-- Joe
the runners that i started on and a base that i started to siemesed are for sale.
Old Nov 4, 2004 | 03:55 PM
Car: 89 Formula
ok then well the question then gets to be has anyone done any testing on this type of mod like before and after dragstrip times even the sotp dyno tests cause in theory it seems promising
Old Nov 4, 2004 | 08:17 PM
91banditt2's Avatar
Engine: 5.7 HSR
this guy did some testing
Old Nov 5, 2004 | 01:32 PM
Car: 89 Formula
yeah but im not talking about a siameased base im talking about just fully siameased runners now in theory a fully siameased runner would act like an extention of the plenum cutting the efective runner length down to just the base manifold which is like 6 inches you made a set of runners like im talking about correct? what differences did you notice when you put them on the car?
Old Nov 5, 2004 | 01:40 PM
anondude13's Avatar
If I'm not mistaken, that guy leaned out cylinder #7 with that setup.
Old Nov 5, 2004 | 02:03 PM
Car: 89 Formula
yeah but thats a siameased base im talking about just making the runners like 1 big runner like this
not siameasing the base, that causes bad magic in the 5 and 7 cylinders
Old Nov 6, 2004 | 02:35 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
I recall hearing that the problem in # 7 cyl. that guy had after siamesing the base had nothing to do with the intake itself, it was a mechanical problem that was eventually discovered.
Old Nov 10, 2004 | 12:46 AM
Car: 91 Formula
Engine: 383 HSR
Axle/Gears: 3.89
siameseing the runners is not really like having a larger plenum because the runners are still not all connected except in the plenum area. it just increases the volume of each runner. so the runners are still the same length just larger for about half the distance.
Old Nov 10, 2004 | 07:31 AM
91banditt2's Avatar
Engine: 5.7 HSR
--Joe
i wonder how this person is doing with them.he's only the forth owner of these runners.
Old Nov 10, 2004 | 08:58 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Good question.. They were decent runners, just the TPI that I couldn't deal with anymore.
My singleplane brought me into the 119mph range in the 1/4 on a very tired 5 year old long block.
-- Joe
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
tazs2000
Jul 15, 2017 08:44 AM
87iroctheo
Dec 4, 2016 11:47 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
