intake leak or valves leaking??
Old Oct 30, 2004 | 07:34 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
ok i did an intake manifold gaskets, and new injectors, and new egr, now that its all done it runs like crap sounds like a lawnmower, looping idle, loss of power, misfiring, ok so i pulled the distubtor and was going to number one cyl, when i heard a hissing sound every time i got to a compression stroke, so im thinking its a intake leak, or valves leaking, during a compression stroke when turning the engine the crank pulley by hand could you hear an intake leak??
Old Oct 30, 2004 | 10:29 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Not enough information. Do a leakdown test.
Old Oct 31, 2004 | 10:47 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Where is the sound coming from? If it was an intake leak you would have to have bad valves first.
Old Nov 1, 2004 | 05:08 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I hear hissing sounds when I crank it over by hand. It's normal. Check the timing. Check for vacuum leaks. Check for fuel leaks near the O-rings on the inj. Check fuel pressure.
You didn't do anything to the valve train and I have a hard time believeing that something broke all by itself.
Old Nov 1, 2004 | 07:47 AM
porkyzilla's Avatar
Engine: 5.7tpi 350,
checked fuel pressure, at 48-52psi, brand new injectors, and o-rings, no leaks, if a the wires were mixed would it still time to 6 degrees??
wayshegoes
Aug 17, 2015 12:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
drathaar907
Aug 6, 2015 04:20 PM
