IROC just died???
Old Oct 31, 2004 | 04:50 PM
GM Man's Avatar
Car: 1986 2.8 Camaro
Engine: TPI 350
Transmission: Tremec TKO
IROC just died???
I drove home from work the other day and everything seemed to be working fine. Its a 89 IROCZ TPI 350. I had just replaced the alternator about two days before it died also. Now I go out to start up the car and it just cranks over with nothing. I checked the fuel pressure and it was up at 47lbs. so I pulled the number one plug and had no spark. Which leads me to believe that the ignition module is dead in my distributor. Is there any other parts in the distributor besides the ignition module that could affect the firing??
Thanks.
Old Oct 31, 2004 | 06:59 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Coil, right next to the distributor.
Ed
Old Oct 31, 2004 | 07:03 PM
bluroc's Avatar
Car: 1985 Iroc-z Camaro
Engine: L69 5.0 HO
Transmission: 5 Speed
Also the pick up coil inside the distributor.
Old Nov 1, 2004 | 09:26 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
It could be your computer as well. Are your injectors pulsing?
chazman
Aug 28, 2018 03:25 PM
bamaboy0323
Sep 3, 2015 06:07 AM
chazman
Aug 22, 2015 02:01 PM
EFR2000
Aug 18, 2015 08:54 PM
mustangman65_79
Aug 11, 2015 03:17 PM
