Throttle Position Sensor
Old Nov 4, 2004 | 12:28 PM
Oshdog's Avatar
Car: All GM
Engine: All Chevy
Transmission: TH350 / 700R4 / 4L60E
Axle/Gears: custom GM 8-1/2" 456 posie
Can anyone please tell me what the Throttle Position Sensor does?
I assume it sends a signal to the computer. But what does the computer do with this
information? Does it adjust timing? Control the fuel injectors?
Also, if my Throttle Position Sensor is out of adjustment, how will it react on the motor running and performance? lastly, if the Throttle Position Sensor was out of adjustment when I did my base timing will the base timing still be incorrect?
Old Nov 4, 2004 | 12:40 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Timing and TPS are seperate systems. While both can affect performance, neither affects each other.
*my bad, I was thinking of base timing..
If the TPS is out of adjustment it will cause performance to suffer. Some adjust it and get better responce, but I'd rather just leave it at the stock setting.
To adjust it, read up on these links.
http://sethirdgen.org/tps.htm
Old Nov 4, 2004 | 02:23 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
The TPS simply tells the ECM what position the throotle plates are in. The ECM uses this info along with a bunch of other stuff to decide on timing and the injector pulse width (PW).
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
