where can I buy a new ecm and maf??
Old Nov 5, 2004 | 06:14 AM
subgunman's Avatar
Looking for a resaonable source for a new MAF and ECM other than the rebuilds at auto parts stores. We put a new motor in my sons 88 and the MAF (now we know) was bad yet the ecm never threw a code 34! It would constantly thow a code 43 and tried replacing all the parts listed under code 43 (or is that 42??) except the ecm.
Well, now we have to pull the dam motor back out because it is apparent it ran rich due to one or both of these items being faulty and washed the rings out.
Initially, we did get a rebuilt unit from oreilleys and try it (maf) because the car would surge at idle on a regular basis and even though the code did not suggest it, I wanted to try. Rebuilt unit from oreilleys made zero difference so we took it back. Come to find out from talking to a local mechanic, it is not uncommon to go through three or four of those auto part stores rebuilt units b4 you find a good one!
I believe the problem is with both the maf (car finally would not stay running till I disconnected maf completely) and the ecm both. The ecm is a rebuilt unit also.
Where can I find a new or GUARANTEED refurb unit?????
To make it a little more complicated on the ecm, I had ed wright burn me a chip fopr the ecm I have so I would most likely need a specific ecm.
Any help would be greatly appreciated!!
Thanks guys
214-882-8850
jeff schramm
Old Nov 5, 2004 | 09:14 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Taken from Auto Zones web site
88 MAF
are you getting a code 12?
Old Nov 6, 2004 | 05:05 AM
subgunman's Avatar
code 12?
nope have seen one of those. what is a 12?
Old Nov 6, 2004 | 06:50 AM
91banditt2's Avatar
Engine: 5.7 HSR
a code 12 is the very first code that the ECM should flash.
flash (long pause) flashflash
that code should come up every time you check your codes.
Old Nov 6, 2004 | 09:00 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Is that Wells MAF from the Autozone website the one that is higher flow than stock? I thought it was more expensive than that.
Troy
Old Nov 7, 2004 | 05:09 AM
subgunman's Avatar
code 12
oops, duh. yep it flashes a code 12 when I hook up the tech 1a every time.
Old Nov 7, 2004 | 09:52 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Get an ecm from a junkyard, ebay or off of the classifieds from here. I am sitting on 3 730's and 1 165 myself. There is a listing of all the ecms from different cars that are avalible to be used.
Old Nov 8, 2004 | 08:41 AM
subgunman's Avatar
ecm
ok, what would you like for one of yours and are you sure they are good?
thanks
p.s. how do i tell the diff between a 730 and a 165?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
willyjoejr
Sep 3, 2015 09:26 AM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
