Custom Cold Air Intakes
Old Nov 7, 2004 | 05:16 PM
needles's Avatar
i'll be making my own cold air intake kit for my 87' iroc 305 soon.
i did a search,and found the plans i need,but i have one question.
most people have the filter going down towards the passenger side fender,where the vacuum resivoir is. my battery is there,and the vacuum resivior is on the drivers side. it seems easier to go towards the passenger side,as opposed to the drivers side.
should i try to rig it up so i can go to the drivers side,if nothing is in the way,or just go near the battery?
thanks again
Old Nov 28, 2005 | 10:20 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I know this is old, but no one seems to want to address this situation.
I'm in the same boat. I can't see running the pipe over the upper radiator hose to be that efficient. Relocating the battery to the back is expensive, and to the other side significantly lengthens wires because of the alternator being on the passenger side like the battery. I also see the filters set atop the battery.... which doesn't seem to "cold" to me. The factory TPI air intake setup is costing me 5-7HP. When I take it off on the dyno, I gain that back. So if it's unrestricted and cold, I hope for another HP or two.
Old Nov 28, 2005 | 12:47 PM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
summit has a battery relocation kit for like $45....i would use that
Old Nov 28, 2005 | 01:10 PM
It's not sealed, so it wont be NHRA legal. I do race at the track, so that's a consideration.
Old Nov 28, 2005 | 03:32 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Plus remember if you put your battery in the trunk you need to have an on/off switch out the back of the car.
Old Nov 28, 2005 | 03:44 PM
Car: 89 Formula
Engine: 5.7 TPI
what was i thinking
Old Nov 29, 2005 | 07:10 PM
Shagwell's Avatar
Car: projects.......
run it to the drivers. My car came w/ basically the SLP cold air kit. This was stock for my GTA. My battery is factory on the driver side, so my air intake went to the passengers. Either fab up an intake placing the filter onthe driver's side, or relocate the battery to either the driver's side or the trunk and route to the passengers. - also, if you run a gel or dry type battery, it doesn't have to be enclosed to be NHRA legal...
Old Nov 29, 2005 | 07:33 PM
I am familiar with the GTA setup. Runs to the passenger side. I had considered moving the battery to the driver's side...
Old Nov 29, 2005 | 09:37 PM
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
wel i was gonna have this guy mandrel bend tubing for my intake. i dont know how to use photoshop but yeah sorry for the crude artwork. but yeah you get the idea. intake piping to 2 filters behind the foglights.
Old Nov 30, 2005 | 12:11 AM
Hawks Thirdgen has something like that already that you can buy. IMHO I wont do anything. The air coming in is pretty cool from that place already. The best thing you can do is cut out the air box below the filter, and take out all the baffling underneath.
My problem is the shell over the radiator is too small. Costs me 7HP on the dyno.
Old Nov 30, 2005 | 12:20 AM
Car: 1987 IROC
i already have the baffling out and its cut out. i want it also for looks too sort of. oh and the guy thats gonna do that is gonna solve that problem with the flat spot there by cutting a little off my hood.
Old Nov 30, 2005 | 06:58 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
HMM
Have any of you tried putting the filter right onto the tpi opening, like they do on impalas and caprices, when making cold air intakes.
Old Nov 30, 2005 | 09:42 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Do a search CandiedZ has a nice cold air intake before he did the ls1 swap.
Old Nov 30, 2005 | 10:04 AM
Re: HMM
You mean, bolt the filter to the throttle body diectly?
That's alot of hot air, if that's what you mean.
Old Dec 1, 2005 | 02:14 AM
doc76239's Avatar
Engine: TPI 305
Yep
That's it. I'm up here in the Washington were sucking in water is more of a problem then hot air.
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
