what intake 4 tpi 406
Old Nov 8, 2004 | 11:38 PM
greenfrogg's Avatar
Car: 89 FORMULA355 80 TURBO TA 355
Engine: 355 tuneport 355 chev CARB
Transmission: 700 350
ok i finally got a 406 now i need to find out how to make my 89 intake work on my dart heads so do i go after market or could the factory one be fixed to work :hail: thanks 4 any info
Old Nov 9, 2004 | 08:58 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Just go stealth-ram, let it breath.
Old Nov 9, 2004 | 11:30 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Or super ram....
Old Nov 9, 2004 | 12:15 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
I vote stealthram
Old Nov 9, 2004 | 12:38 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
If hood clearence and smog arent an issue (which i doubt would be because u are building a 406), i would go with a stealth ram.
Old Nov 9, 2004 | 10:58 PM
greenfrogg's Avatar
yeah stealth ram is what i was thinkin noticed sticky after posting stealth ram has both patterns[intake].. looks like you have to go with whole kit ..was hopin 4 intake swap now and maybe work from there,butt noticed nothin is compatible with stealth ram ....fuel rails ... thanks 4 all youre imput this site rules :rockon:
Old Nov 10, 2004 | 02:07 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
The million dollar question. What cc are the intake ports of your Dart heads? That will make the decision on what intake you will run. Anything 215cc and bigger will require welding of the HSR or LT1 intake. Only the Miniram has an intake that will direct fit large cc heads.
Old Nov 10, 2004 | 11:34 AM
greenfrogg's Avatar
well i just got the engine the guy said there sportsmans and they were 800 a set ..so im thinkin the 200cc ones ....ill have to see thanks 4 any input they are world products i thought they were darts
Old Nov 12, 2004 | 10:02 PM
greenfrogg's Avatar
what about the edelbrock i see its a lil cheaper is that cuz it sucks ?
Old Nov 12, 2004 | 10:15 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Re: what intake 4 tpi 406
Are you also asking how to make the 89 base work with the Dart heads also? If so, you need to elongate those centerholes that are drilled at 72* to find "standard" SBC heads.
But, as others suggest, consider a different intake in the long run. The TPI just flat out runs out of breath too soon, especially on a big mouse like your 406.
Old Nov 13, 2004 | 08:18 AM
greenfrogg's Avatar
so the stock 1 can bee drilled out? i am thinkin after market just dont want 2 pay full price.... so lookin 2 see what 1 is most desireable. then find 1 in the classifieds or....my eng has ross flat tops pink rods and for the moment 525 crower hyd cam steel crank .. if that helps any. thanks again:hail:
Old Nov 13, 2004 | 08:27 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Do you need to pass smog? THAT is the million dollar question.
Old Nov 13, 2004 | 05:30 PM
greenfrogg's Avatar
no smog laws here all though with the set up i have in the car all smog is still hooked up.[i know its robbin power just havent taken it out ] no plans on hookin that crap up on 406 though... thanks again 4 reply:rockon:
Old Nov 13, 2004 | 10:01 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Miniram with the appropriate cam.
Old Nov 13, 2004 | 11:03 PM
greenfrogg's Avatar
youre talkin about the tpis 1 ..write........that place isnt 2 far from me ..i looked at them butt at over a grand not very affordable butt what iz ....... thank 4 youre 2 cents
Old Nov 14, 2004 | 05:43 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
If I were to do it all over again, I would modify a single plane intake manifold for EFI. Stock TPI stuff cannot properly support a big inch small block. I ran a SR base with SLP runners and a 58mmTB....it was okay but the motor ran out of breath at 5000rpm.
Old Nov 14, 2004 | 06:40 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
406 I'd say the same (miniram) to you as well, so long as you don't have to pass smog.
green - If it's too rich, search for the LT1 Conversion and call John.
Old Nov 14, 2004 | 06:54 PM
406TPI's Avatar
Car: 1985 IROC-Z
I wouldn't put a miniram on a motor unless somebody gave me one. Not that it isn't any good, I just wouldn't waste the money when I could put together an efi single plane unit that would be more effective....and cheaper
Old Nov 14, 2004 | 10:31 PM
greenfrogg's Avatar
hey there 406 i was hopin 1 of you 406 guys were gonna pop in . iwas checkin out those intakes also .what about the throttle body's ? are theese the holley units or do you get 1 else were? im tryin to do this with as much stuff i allready have. ive seen a intake 4 $500. vic jr with fuel rails [like u were talkin about] is this goin price? thanks everyone
Old Nov 15, 2004 | 02:41 PM
greenfrogg's Avatar
just read about the lt1 set up ... sounded pretty good butt..........i was hopin 4 a lil quicker time than 12s looks like a stealth ram time .:lala:
Old Nov 15, 2004 | 05:14 PM
ChevelleFan's Avatar
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
Cheaper? Before or after you buy a throttle body?
Seriously though, I'm about to put a ported TPI on my MegaSquirted 406 and have read all 'it-wont-run-over-5000rpm' stuff.
What are you single plane guys doing for throttle bodies? Keep in mind, this is supposed to be the 'cheaper' route.
You want a nice one from Holley? Thats over $600! I really don't have the machines to make a custom adapter like antheses (sp?) did with his setup and Vortec throttle body. I like the idea, I just don't have the tools or know-how on this one.
It doesn't need to be pretty (although it'd be nice), but it needs to be functional first. Holley and Edelbrock carbs cost around $250-280 new. An EFI throttle body shouldn't cost more.
-Dave
Old Nov 15, 2004 | 05:20 PM
406TPI's Avatar
Car: 1985 IROC-Z
-Dave
I didn't say cheaper for you, I said cheaper for me....but then again I'm a pretty resourceful person. I have a bridgeport and a tig welder at my disposal too
Old Nov 17, 2004 | 02:12 AM
Engine: 4.0L
You want quicker then 12's? How much money you got? It really doesn't matter too much what intake you have, you can go as fast as your wallet can afford.
Old Nov 17, 2004 | 02:38 PM
greenfrogg's Avatar
12s aint nuttn i can putt a carb on and do that ... im thinkin down the road ..what reason would i go to all the trouble [wiring in and all] to do the same time i could do on a carb set up ? know what i meen? i really like my tpi butt its lookin like i just mite take it out in favor of the carb. im just tryn not to switch more than i have too
Old Nov 19, 2004 | 08:51 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
As you can tell, everyone has their own opinion on an intake for a 406. My choice is the MiniRam. The combination of a 406 with good cam, heads and a MiniRam is a very stout combination.
Mid to low 11's should not be a problem.
www.geocities.com/dzperf
LT1Formula
20
Nov 14, 2015 12:02 AM
masonta
Aug 31, 2015 10:14 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
