Trouble with MAF wires
Old Nov 16, 2004 | 07:08 PM
subliminal's Avatar
When I went to start my car this morning the Alternator Snagged the wires to the MAF and ripped two of them apart. If I spliced the wires back together will it fix it? If not how should I go about fixing this? Thanks alot.
Old Nov 16, 2004 | 07:23 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Go to a junk yard and get one there and then splice it in.
Old Nov 16, 2004 | 08:15 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
Re: Trouble with MAF wires
Yes you can splice into them making them longer sauder and reconnect them and it will work fine(take your time). Use the same gauge wire or a size thicker and be sure to use shrink wrap (twice) on all connections and cover everything back up and out of the way.
dissconnect the battery before you start so not to short anything out
Old Nov 16, 2004 | 09:00 PM
Guest
Guest
Posts: n/a
Ahhh... done that one before. Mine have been spliced for, oh, about 10 years now. I decided I'd be smart and rerouted the wires on the opposite side away from the alternator, and got to add another splice when the fan buzzed its way through one of them.
Careful where you put them, try to find a safe spot.
Old Nov 17, 2004 | 06:19 PM
robsgta's Avatar
use plenty of wire zip ties..some of these wires can catch fire I have seen that happen before.
89GTAOz
May 16, 2020 09:31 AM
chazman
Aug 28, 2018 03:25 PM
trevor1010
Aug 24, 2015 08:34 PM
Bert87
Aug 23, 2015 03:50 PM
djmarch
Aug 19, 2015 12:07 PM
