TPI Low End Power Issues....
Old Nov 21, 2004 | 05:52 PM
91RSHawaii's Avatar
Car: 1999 30th Anniversary Pontiac T/A
Something strange I just noticed the other day going up my driveway (45 degree basically), my z28 cannot make it up without dying (flooring it too), but my old RS did it, piece of cake.
It seems that I'm clearly lacking a load of low end power.. but I dont really know whats up. Anyone got any ideas?
Old Nov 21, 2004 | 10:26 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Check your timing and TPS setting.
Old Nov 21, 2004 | 10:37 PM
91RSHawaii's Avatar
excuse my ignorance, but how exactly would i go about doing that?
Old Nov 22, 2004 | 03:26 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Huh? Flooring it in low gear and it won't climb the hill? Something is seriously wrong. If I had my car in first gear and floored it the rear tires would be smoking, and I only have an LB9.
Old Nov 22, 2004 | 03:31 PM
Wolfpack's Avatar
Car: 86 Iroc
Just wondering but is the Transmission shifting correctly? TPI cars are torque monsters right off idle...any hill shouldnt be a problem if you have traction.
EDIT: doh just noticed you have a T-5....ok nm about the Tranny shift thing Course maybe excessive clutch slipage..but you would smell that.
Old Nov 22, 2004 | 03:34 PM
kevinc's Avatar
Car: 1982 Z28
Procedures for this are found in the Tech Articles section off the main page, or in a manual.
Old Nov 22, 2004 | 07:08 PM
snowman89's Avatar
Car: 1989 IROC-Z Camaro
Engine: 5.8L 355
Transmission: T-5 5-speed
I hope that when you went up the hill you were at least in 1st gear. I just thought I'd add that in.
Old Nov 23, 2004 | 01:19 AM
91RSHawaii's Avatar
yep i was in first gear... car just feels wierd.. like theres not enough torque or something.
Old Nov 23, 2004 | 01:21 AM
91RSHawaii's Avatar
oh yeah, what should my car be idling at? its currently idling at around 900 rpms
jaridjohn
Jul 8, 2024 03:49 PM
Vintageracer
Jan 10, 2020 05:33 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
novaderrik
Aug 10, 2015 12:44 PM
