Injectors won't fire
Old Nov 28, 2004 | 09:53 PM
JOHNCOO5's Avatar
Car: 85 IROC-Z
Engine: 5.0 TPI
I just finished all the wiring on my 85 5.0 tpi/87tpi ecm and harness, thanks Trickster. But I can't seem to get the injectors to fire. I have power to them but when I hook up my "noid" light and crank it over I get no flashing light. Any help would be great, this thing has almost worn me out!!
Old Nov 28, 2004 | 10:07 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Just curious here John, but how did you determine that you had power to the injectors?
Old Nov 28, 2004 | 10:13 PM
JOHNCOO5's Avatar
Car: 85 IROC-Z
Engine: 5.0 TPI
Test light hooked to ground and probe the two terminal on the inj harness w/ key on.
Old Nov 28, 2004 | 10:19 PM
TPIJeep's Avatar
Engine: 7.4 L of Small Block Fun...
When you try and start it does it spit and pop and are the plugs wet with gas?
I would check to make sure you have high impedance injectors, my first setup burned up the ECM injector Driver because I was sold low impedance injectors.. same result, steady noid light when cranking, put your digital multimeter on the injector terminals (not the harness) and read the ohms, your looking for 12-14 for high and 2-3 for low. If they are low then you probably fried the injector driver and will need to pick up a new ecm, the PROM will be okay.
Old Nov 28, 2004 | 10:27 PM
JOHNCOO5's Avatar
Car: 85 IROC-Z
Engine: 5.0 TPI
When I try to start it it sounds like it is going to run for a second but then it won't, plugs are still dry, just checked them before I tried it yesterday. I do have the High impedance inj.'s, checked that too, but you said steady noid light while cranking, I get no noid light. Only power to each term on the inj.
Doug
Old Nov 28, 2004 | 10:28 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You have e-mail!!!!!!!!!!!!:lala:
Old Nov 28, 2004 | 10:37 PM
JOHNCOO5's Avatar
Car: 85 IROC-Z
Engine: 5.0 TPI
Thanks Trickster I'll go over the charts you sent and see what I can come up with. I'll keep you posted.
Thanks,
Doug
Old Nov 29, 2004 | 08:14 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
When this happened to me, it was the electronic module in the distributor. Took me about two weeks to figure that one out.
Old Nov 29, 2004 | 08:38 PM
JOHNCOO5's Avatar
Car: 85 IROC-Z
Engine: 5.0 TPI
I took the module to Auto Zone and had it tested yesterday, is it possible that the tester was wrong? We tried it 4 or 5 times. Each time tested good. The troubleshooting tests that Trickster sent me are very "in depth" and test results from them show the ecm to be bad. This is a used ecm, but it is the 2nd one I've tried, but not for sure if either one was good. The prom is used also for that matter. Supposed to be good, but who knows? Can I have it tested somewhere? I don't know, maybe I'll just buy a new one?.:lala:
Old Nov 30, 2004 | 03:18 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Are you using Accel injectors? If you are, that's the problem. If not I would still say it's a bad injector. The bad injector is knocking out the injector driver in the computer.
Old Dec 1, 2004 | 11:16 PM
JOHNCOO5's Avatar
Car: 85 IROC-Z
Engine: 5.0 TPI
Nope, stock inj.'s.
All of my inj.'s tested @ 16ohms could I still have a bad inj.?
Explain?
Old Dec 1, 2004 | 11:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you have 16 OHM's across all eight injectors they are okay. The only way you would have a problem with the injector itself right now would be if they were old injectors that had not had any gas through them in awhile. Then they could be gummed up and the pintles could be stuck closed. Since you are not getting a pulse from the noid light that does not seem to be the case here.
Old Dec 1, 2004 | 11:30 PM
JOHNCOO5's Avatar
Car: 85 IROC-Z
Engine: 5.0 TPI
Well that answers that ? I just asked you on the electronics board. Thanks Trick, I guess I'll go ahead and get a new ecm and if that doesn't work then I'm sure youll hear from real soon.
Doug:lala:
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 21, 2015 07:20 PM
justin57
Aug 20, 2015 07:05 PM
