Intake Runners
Old Dec 2, 2004 | 11:04 AM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
Intake Runners
What is better for a 305 G92
Slp Runners Siamesed.
Length- 6.625
Diameter- 1.600
TPIS Runners
Length- 7.625
Diameter- 1.660
Stock Runners
Length- 7.250
Diameter- 1.470
Please I just had one of my friends check out SLP for the order @ an auto parts store. I dont care about the price but from what i just read the stock runners are worth more than slps. Thank you
Old Dec 2, 2004 | 12:23 PM
VetNutJim's Avatar
Car: Different One Every Day
Engine: LS1,LS6,L98,L83
Transmission: 700R4, 4060E,Turbo 350, Turbo 400
Stock runners.
Old Dec 2, 2004 | 01:15 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
SLP
Old Dec 2, 2004 | 01:26 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
stick with stock runners. make a custom plenum if anything.
Old Dec 3, 2004 | 11:21 AM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
I dont know I hear different stuff everywhere I go I'm kinda looking for results and someone with a profound knowledge of TPI. I know that the longer the runners, the better the torque curve and greater the torque. And as anyone who is into cars knows that a greater cfm rate generally equals more power unless you over do it.
So my point is even though the SLP's are cheaper and come highly recommended would the TPIS runners be better? More flow, longer runner though not siamesed.
My final intent for the tpi is to eventually change the lower intake manifold probably again look into tpis, because they have the highest flow rate i have seen for a true tpi system, the manifold is port matched, even though im not a big fan of edelbrock. Plus the polished aluminum will always get me over natural cast. Then, have the plenum polished and ported and have all of the interior blockages air brushed away. 52mm Holley Throttlebody and I haven't seen anything for fuel rails. If anyone can show me the pros and cons to my current plans please explain.
I do not want to lose the cars low end torque but I would like to definitely increase high end horsepower. I am definitely still learning and know very little but I do believe this could add at least fifty horse if not give it the potential for it, then I can finish the exhaust and port the cylinder heads. Thank you for your time.
Old Dec 4, 2004 | 10:43 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Mcdamit:
Your plan above is just fine, EXCEPT for the 52mm TB. A 52mm TB will get you nothing on a 305. Save the money on the 52 TB, keep the stock TB and spend the money on a good cam. You are guaranteed (sp) to get much more gain from a cam than a 52mm TB.
My 2 cents worth.
Old Dec 4, 2004 | 10:52 AM
Parrydise7's Avatar
BTW, IIRC, TPIS runners are from ASM.
customblackbird
Oct 1, 2015 04:30 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Rally Smith
Sep 14, 2015 06:59 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
