1987 TPI Engine Wiring Harness
Old Dec 12, 2004 | 07:07 PM
87 B4Z TPI 5Spd's Avatar
http://www.darklair.com/TPI.html
"1987 is a good year for the wiring harness. It's the last year of the separate engine harness (non-integrated) and the first year for dual fans."
I copied the statement on the above TPI Website. What does he mean about 1987 having a separate engine harness, non-integrated?
Old Dec 13, 2004 | 11:42 AM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
Stand-alone harness means the computer harness is separate from the body harness (ie. headlights, horn, turnsignals, etc.). This setup is easier to swap into a non-EFI car, because you won't have to pick through a huge harness and pull out only the wires you need; the General did it for us.
I used an '87 LB9 motor and harness in my '88 Monte SS.
Old Dec 13, 2004 | 02:27 PM
Must be a real pain to replace an engine harness in an '88-'92 Fbody. Not that '87 would be real treat either.
More trivia for the file.
Thanks.
Old Dec 15, 2004 | 07:56 AM
Oshdog's Avatar
Car: All GM
Engine: All Chevy
Transmission: TH350 / 700R4 / 4L60E
Axle/Gears: custom GM 8-1/2" 456 posie
Go Painless
I have an 87 GTA and transplanted the drive train into another body that was not rusted.
Point being, the 87-factory wire harness is a mess also. Best solution in my opinion is to buy a Painless harness or make your own.
Old Dec 15, 2004 | 05:15 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I did not know that.
I happened to buy an 87 TPI setup for my swap and I figured they were all like that.
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
R3500
Aug 17, 2015 12:16 PM
