plenum siamezing? (sp?)
Old Dec 13, 2004 | 11:42 AM
l98+t5's Avatar
Car: 1988 camaro iroc-z z-28
Engine: L98 5.7 liter 350
Transmission: T-5 manual 5-speed
i have a completely stock tpi 350 and i am cleaning and flowmatching the injectors and i have the plenum off and no money so i was wondering if there are any benifits to siamesing the plenum while using the stock runners and baseplate? thanks
Old Dec 13, 2004 | 03:03 PM
KiLLJ0Y
Guest
Posts: n/a
nope.. wont be worth a damn thing without siamiezed runners and a larger intake manifold to flow the more air.
dont waste your time.
Old Dec 13, 2004 | 03:58 PM
l98+t5's Avatar
ok thanks for the tip i would have done it otherwise thanks have a good one
Old Dec 13, 2004 | 05:14 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I have a 91' LB9 and i gained alittle low-end when i siamesed them. While its off go ahead and cut down your egr walls right behind you throttle body opening.
Old Dec 13, 2004 | 05:17 PM
KiLLJ0Y
Guest
Posts: n/a
yes that will help... but he was asking about the stock runners and siamiezing the plenum.. theres no benifit there..
but do the EGR Walls so its a clear air flow to the runners.
Old Dec 14, 2004 | 01:56 PM
l98+t5's Avatar
ok ill do that. do you guys know of any other way to gain some ponies while ive got it off? keep in mind evrything is stcock?
88SS6SPEED
Nov 11, 2015 07:05 AM
toronto formula
19
Oct 6, 2015 12:27 PM
italiano67
Sep 22, 2015 08:42 AM
