Head or Intake Gasket Blown?
Old Dec 14, 2004 | 04:46 PM
RyanZ48's Avatar
Car: 1988 Camaro Iroc-Z
Engine: 305 Tuned Port
Transmission: 700R
I have a 1988 Iroc-Z with a 305 Tuned Port. The engine runs and drives fine (no misses) but my temp gauge has now gotten to where it runs a lot warmer than it used to.
I've had to replace the Intake Manifold gasket once before because of a visible leak. Now I'm wondering if my problem is the Head Gasket or the Intake.
When I run it on the Interstate it gets hotter than driving in town. I can drive for 20 to 30 miles on the Interstate fine but usually anything more than that and it starts to run hot.
I replaced the thermostat and radiator cap and noticed that there was an unusual amount of water at the end of the tailpipe.
What would any of you think would be the most likely cause?
Thanks,
Ryan
Old Dec 15, 2004 | 10:44 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
i found a problem one time to be my radiator and a bunch of junk clogging it up. resticting ar flow.
Old Dec 16, 2004 | 12:32 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
is your a dam still there that pushes air up to radiator for cooling
Old Dec 16, 2004 | 12:33 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
any coolant loss?
Old Dec 16, 2004 | 12:39 PM
RyanZ48's Avatar
Transmission: 700R
There's no "visible" coolant loss and a minimal amount at the tailpipe after starting it. When it does run hot and when I let it cool down I have to add some coolant. I also noticed that the coolant reservoir is always about half full but the radiator doesn't pick this up.
There are no restrictions in the cooling system that I'm aware of and the coolant is clean and I can see it flowing through the radiator.
When I have the radiator cap off, and rev the engine, some water will shoot out of the radiator. Any time I have seen that on other cars it turned out to be the head gasket. But since I've had trouble with the intake gasket twice, and the last time I took the intake off I noticed that the end of it on the passenger side wasn't in the best of shape, I'm now wondering if a blown intake gasket could cause any of these same problems? The intake was a little rusted and pitted at the very back and on the passenger side.
LT1Formula
20
Nov 14, 2015 12:02 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
86White_T/A305
Aug 17, 2015 12:16 AM
