MAF or speed density?
Old Dec 15, 2004 | 09:49 AM
l98+t5's Avatar
Car: 1988 camaro iroc-z z-28
Engine: L98 5.7 liter 350
Transmission: T-5 manual 5-speed
what years did the tpi engines have speed density and what years had MAF because i have an 88 350 and it has MAF but wasent it speed density in 88 ?
Old Dec 15, 2004 | 10:17 AM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
'87-'89 was MAF, '90-'92 was speed density.
Old Dec 15, 2004 | 10:29 AM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
A little off topic. Is there a place I can read up on them and compare so I can see first hand what is better about a SD set-up.
Old Dec 15, 2004 | 10:44 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
85-89 maf
90-92 SD
Old Dec 18, 2004 | 10:42 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
To be more precise:
'85 MAF
'86-88 MAF
'89 MAF
'90-92 SD
Old Dec 25, 2004 | 09:51 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
85 is the year of maf to avoid. well if you already have maf then run it. no need to get into a sd swap if the maf system you have is working fine.
Old Dec 25, 2004 | 10:10 AM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
Whats wrong with 1985 MAF's? Seriously? Never heard anything about that. Other than my ECM being crappy but thats it.
Old Dec 25, 2004 | 10:21 AM
Car: 1988 IROC-Z
in 85' they used the MAS module for burnoff control. the module is expensive to replace when it goes south. with the later 86-89, burnoff control was also intergrated into the ecm instead of using a seperate module.
yes the 85 <-ecm was slow.
Old Dec 26, 2004 | 12:53 PM
Yeah I know it is slow, why pain me more by telling me again? lmao.
Thanks didn't know that.
BumpaD82
Feb 26, 2016 02:57 PM
Nick McCardle
Sep 10, 2015 08:36 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
