Weird Question
Old Dec 21, 2004 | 01:18 AM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
Weird Question
Ok... the TA got wrecked this weekend. And i have an offer for a Formula Shell. What i wanna do is take my motor/trans, put it in as well as the TPI, but my question is. Is there a way to run the TPI, with injectors *(its a SD system) no emissions eguipment whatsoever, as in just the intake, injectors, motor, and a little wiring harness, ill keep the Knock sensor, and 02 sensor, and whatever else is necessary for the computer to control timing, but i dont want anything else, get what i mean, if anybody has the file that i can use to burn a new chip without any of this stuff that would be great
Old Dec 21, 2004 | 10:06 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
All the AIR stuff can be removed with no computer modifications. It could care less. I don't run this junk on anything I own. Removing the EGR will set a code. This can be programmed out though. Otherwise everything else is essential to proper operation. You aren't going to significantly reduce the amount of wiring involved in the TPI system.
Cleotiz
Jan 6, 2018 08:56 PM
87iroctheo
Dec 4, 2016 11:47 AM
NiG
Sep 2, 2015 06:54 AM
CORV3TT3
Aug 23, 2015 11:26 AM
redmaroz
Aug 16, 2015 11:40 PM
