Custom Air Duct and filter for custom TPI install
Old Dec 25, 2004 | 01:06 PM
TPIJeep's Avatar
Engine: 7.4 L of Small Block Fun...
Does anybody make custom ducting, elbows ect for a custom TPI install?
The little K&N that clamps to the throttle body is a joke I have got to have more filtering area due to the high dust areas I drive in. If I could go from the oval TB to say a 4.5-5" tube I could work from there..
The 90 degree elbows they make for the LT1 would work if the opening was bigger then 3.5" that has got to be a hell of alot of restriction for a 58 mm TB and 454 cubes.
Thanks for the input.
Old Dec 25, 2004 | 09:37 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Try the www.ModYourCar.com.au web site. They list quite a variety of silicone hose. I would think 4" would be more than large enough. That is also what fits on your throttle body. Three and a half inch will work just fine. The 58mm throttle body has 8.190 square inches not taking away for the shaft and blades. A 3 1/2" pipe has 9.62 square inches. A four inch pipe has 12.56 square inches. So you can see the 58MM throttle body is the restriction on anything with a 3 1/2 pipe or larger. Hope this helps. Allen
Old Dec 25, 2004 | 09:45 PM
brutalform's Avatar
Not only is the clamp on filter small, it will injest hot air also.
Old Jan 4, 2005 | 02:58 PM
bsmith3188's Avatar
go to jtrpublishing.com
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
TheExaminer
Aug 26, 2015 04:59 PM
wruiz
Aug 13, 2015 09:07 PM
Sanjay
Aug 12, 2015 03:41 PM
