Not running well?
Old Dec 26, 2004 | 01:29 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Not running well?
Long story short. I got my bird, and bought a 383 for it. Let my friend install it cause I don't have the time or place to do it my self.
Anyways, he finally got it together and started it, and he said it sounds like the valves are floating. I'm gonna go by tomorrow and check it out. I was wondering if anyone has any thoughts?
Everything is stock but the long block. And it was running ok before the swap. (it was just overheating, probably due to a blown head gasket, and leaking freeze plugs all over)
Old Dec 26, 2004 | 01:34 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Re: Not running well?
Originally posted by stingerssx
...Everything is stock but the long block. ...
Why not wait until you get there and post up first hand knowledge of the situation rather than second hand info. That never works well.
Old Dec 26, 2004 | 02:06 AM
stingerssx's Avatar
I can't wait. I'd like to go into the situation with some forehand info. Also, if some one else has had this problem, or some info, then that would be great. And I can always add to this thread if I need to, right?
Old Dec 26, 2004 | 04:27 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
...I got my bird, and bought a 383 for it
There's really not enough info here for us to work with. A couple of questions though.
Is this a new engine?
If it's used, did you get some kind of agreement in case of startup failure?
Valve lash may need to be tweaked, but doesn't cause valve float it only compounds it, valve float usaully only occurs when revving the engine beyond the valve train's specifications.
...Everything is stock but the long block...
If new I assume you bought it assembled with intake and heads, pre-run, and maybe even dynoed? If pre-run then valve float is out of the question.
Unless your fiend is responsible for the malfunction I'd suggested calling the dealer before doing anything else.
Look at your warranty, most provide the dealer with reasonable time, and opporunity to repair, or replace, which means you have to return it to the place of purchase, or to an authorized repair shop.
I only exeprienced valve float once when I pushed my engine passed the redline which isn't much for a stock engine, luckily I'd didn't blow the dam thing up!
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
