need some assistance on TPI swap
Old Dec 29, 2004 | 08:24 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
hi, im new to the board, and joined to gain some knowledge on the L98. i own an 87 S10 blazer that currently sports an 89 4.3L V6 that i replaced the 2.8L with. i plan to swap in a L98 V8 this winter. im not looking for swap help, but more so help with the TPI.
i baught a "complete" TPI setup off of ebay reciently. its an 87 intake/plenum/runners, a 90 730 ECM, and a modified stand-alone harness. the problem is that the intake was bare, no brackets for coil, EGR solinoid, throttle cable, basically just fuel rails.
i was wondering if anyone could help me with part numbers. i tryed a search, but came up with few results. i was also hoping for some detaled pics of the intake to show mounting locations and wire routing. i've baught books but there not much help. thanks for any info that can be provided, Jim.
Old Dec 30, 2004 | 05:11 AM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Hope the following will help you some, Jim.
Old Dec 30, 2004 | 05:13 AM
92 Formula's Avatar
Engine: Twin 454's
Old Dec 30, 2004 | 05:18 AM
92 Formula's Avatar
Engine: Twin 454's
Old Dec 30, 2004 | 11:05 AM
S105.7's Avatar
Engine: L98 & L03
thanks 92. i don't think it gets much more detailed than that. im sure that will help a ton. do you know if i can reuse some of the sonsors that are on my TBI? i know the knock is engine specific, but how about MAP, TPS, IAC, ect.
Old Nov 17, 2007 | 02:45 AM
65 Tpi Imp's Avatar
Re: need some assistance on TPI swap
Anychance of some pics for a 85 or 86-89 Tpi System?
Old Nov 18, 2007 | 01:22 AM
92 Formula's Avatar
Engine: Twin 454's
Hope this is what you're looking for.
Good luck.
Attached Thumbnails need some assistance on TPI swap-8588lb9.gif   need some assistance on TPI swap-8588lb9b.gif   need some assistance on TPI swap-8588lb9c.gif
Old Nov 18, 2007 | 11:59 PM
65 Tpi Imp's Avatar
gta90
Sep 15, 2015 04:00 PM
backtothe80s
Sep 5, 2015 12:39 AM
masonta
Aug 31, 2015 10:14 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
