supercharger?
Old Dec 31, 2004 | 01:34 AM
unbonyr's Avatar
supercharger?
ok when you add a supercharger to car people say you will need a tuneup what whould the tuneup consist of i kno i need around 850$ in suspension work some better tires what else id its an stock car and i wont need a rebuilt had one done about 60000 miles ago and about 50000 on the trans will i need a different cam different intake what and hear me when i say need cuase im already rideing on a tight buget but will have enough for supercharger suspension and maybe 750 more on extras and anyone with a bone stock engine with a supercharger on what is your hp and e.t. times or for anyone what you think they'll be expesially for a procharger 9psi the calculater said it should give me 360 rear hp cuase 225stock 60%gain thats 135hp gain so you thaink thats all currect thats the %gain i got from the web site on a stock motor and with 360 hp and good suspension im guessing that should peut me in the mid to high 12s dont you thanks im newbie so if i did somethin wrong please dont think im idiot
Old Dec 31, 2004 | 02:39 AM
z28kindaguy's Avatar
Car: 2004 Pontiac GTO
Transmission: M12
I normally don't like to do this but this is really bad. Please rephrase with proper spelling and puncuation so we can better understand you.
Old Dec 31, 2004 | 05:23 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Whew! You need to include some more info on your car also. What year, engine, tranny, etc.
Old Dec 31, 2004 | 11:15 PM
unbonyr's Avatar
89' pontinac trans am gta 350cubics 700r4 trans
Old Jan 1, 2005 | 12:27 AM
91z28ss's Avatar
Car: 1991 Z28 convertible camaro
Engine: 383 superram
Transmission: Level 4 Vigilante 3000
Axle/Gears: 3:42,Torsen, moser axles LPW girdle
Firts of all, do a search in ``Power adder`` motor for What do I need for a supercharger and then, if your want to be aware of all your needs for your specific concerns, Email Procharger site directly with your ? and they will get vback to you in a few days...
I always wanted a supercharger but since my engine (base) was pretty stock, I ended up builting it stronger and blueprint with a much better intake system. I personnaly find this way better and more suitable prior to go sc.
Pat
Old Jan 2, 2005 | 11:36 AM
klumb15's Avatar
i don't think you can run 9PSI of boost on a stock engine, the compression is way to high to begin with....you will have huge problems with detonation and whatnot...also for a supercharger on a stock engine, its almost a must to have the MSD ingnition mooduel with boost controle to protect your engine...otherwise you'l end up in a world of hurt....i believe with a supercharger, you don't have to do any computer mods or 'tuneup' as you call it, because its forced induction on a computer setup, so your intake air sensor (speed density or MAF) will read the incoming air and react to the change...for a cam, i don't think its a necessity, i believe the S/C kits for FI cars are all based on a stock cam, so you can run with a stock cam, headporting and intake porting will help out your HP, and i think your calculation for HP is a little high...you are 225HP stock crank....then you'll have around 350 crank with the s/c, thats about 290 to the wheels approximately....
InfinityShade
Feb 21, 2016 01:29 PM
toronto formula
Nov 10, 2015 06:17 AM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
