coolant leaking
Old Jan 7, 2005 | 03:07 PM
turismo's Avatar
Car: 1989 Trans Am GTA
coolant leaking
The gta was in storage since last summer because it wouldn't start. After countless part swaps like module and the coil and all that stuff a mechanic finally got it going.
The car's been sitting in the cold since winter started and I start her up every now and then.
I just did that right now and as I was sitting listening to her idle I smelt some coolant. I popped the hood and noticed some smoke and thought it might of been water from the snow dripping in a bit but it turned out to be coolant. It seems like it's coming from the upper rad hose.
The clamp looks tight but I'll have to take a better look at it later. It's freaking cold out and the snow on the hood was heavy so I couldn't lift it all the way.
This is exactly the same thing that happened to my '89 LTD before I left her to rot. I think I'm cursed, any car I own has some kind of coolant issues.
The gta has a new napa waterpump that was put in last year because it took a crap and pissed all over.
Any suggestions or insights as to what could be the worst thing wrong here. Cracked head or something of that nature?. I don't beat the car so there's no reason for it to be serious.
BTW If anyone needs a turdgen make me an offer .
Here's a little picture of where the coolant is. Picture was taken this summer.
Old Jan 7, 2005 | 03:12 PM
kevinc's Avatar
Car: 1982 Z28
Given where it's puddling, it's likely either:
1.) your hose clamp is too loose...
2.) your hose clamp was too tight in the past, and the hose is damaged...
3.) your thermostat housing gasket is leaking (watch that torque spec on the bolts!!)
You're not cursed. Whoever is working on it isn't paying attention.
Old Jan 7, 2005 | 03:16 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I agree. This doesn't look serious or expensive to remedy. If the LTD had the same problem you let a car go to waste....
Old Jan 7, 2005 | 03:19 PM
brutalform's Avatar
How can you post come up on the screen nine feet wide?
Old Jan 7, 2005 | 03:28 PM
turismo's Avatar
because the image is the size of most peoples monitors.
Old Jan 7, 2005 | 03:31 PM
turismo's Avatar
I know man, but when your $1000.00 on the hole and you've lost your job and rent is up other priorities show themselves.
The 302 was eating coolant like crazy though. The back shocks blew out so I couldn't even drive if I wanted.
And the car wasn't a total loss since the frame was rotting so bad that no sane person would drive it thinking that their safe.
Old Jan 7, 2005 | 03:34 PM
turismo's Avatar
I can get a friend to check the thermostat too. I didn't even know there was a gasket there, Does it come with the thermostat when you buy on or is it seperarte?.
Old Jan 7, 2005 | 03:37 PM
vernw's Avatar
Separate usually (at least around here). O'Reilly's/Autozone/Pep Boys all have them for a buck or so.
Old Jan 7, 2005 | 10:15 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
or it could be alittle more seious...could be the water port on the intake manifold...thats a very common leak...just clean it up and try to look at where its comming from.
Old Jan 8, 2005 | 10:11 AM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
red or black rtv silicone works wonders
sheachopper
Jul 31, 2019 11:27 AM
RS Reaper
Oct 17, 2018 07:52 PM
ULTM8Z
Oct 2, 2015 01:25 PM
