TPI 88 and earlier oil sending unit
Old Jan 7, 2005 | 10:42 PM
KiLLJ0Y
Guest
Posts: n/a
i need the T fittings that screw into the block, i dont need the sending unit, just the fittings.. they have been discontinued by GM, anyone have these? its 2 pieces.
OR anyone know what size tube and thread size or where to get ones like it? dealers wont have them.
Old Jan 7, 2005 | 10:50 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you have the part number from GM, go to this site and do a parts search.
https://www.rockauto.com/applet3.html
Old Jan 7, 2005 | 10:59 PM
KiLLJ0Y
Guest
Posts: n/a
no i dont, its # 12 and 13 on this picture
Attached Thumbnails TPI 88 and earlier oil sending unit-oilpressuresender.gif
Old Jan 7, 2005 | 11:21 PM
Guest
Guest
Posts: n/a
12 you can use a tube and elbow, tap one side of the elbow. The other you are on your own. Its basically a hex head fitting with one side shaved on an angle, and then they put a hole in the side of that. All the holes are 1/8" NPT.
Read the text on your picture. What are you trying to do?
Old Jan 7, 2005 | 11:29 PM
KiLLJ0Y
Guest
Posts: n/a
well i was trying to hook up my autometer oil pressure gauge and i needed a place to hook the sending unit.. what size is that other plug with the arrow marked in yellow?
Old Jan 7, 2005 | 11:45 PM
Guest
Guest
Posts: n/a
1/4"NPT
You can use a reducer to 1/8" if need be. Its a common fitting.
Run a tee off that, run your sender and autometer sender.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Irocohio
Aug 12, 2015 08:03 AM
