serpentine conversion question
Old Dec 14, 2005 | 12:31 PM
  #51
pmpnavt's Avatar
Engine: L98 350
Transmission: 700r-4
this is what i did with my car
used stock pulleys, 56.5" belt, and a summit tensioner
i hope it helps everyone
Old Dec 14, 2005 | 06:15 PM
  #52
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i like that...a lot. can you snap some more pics showing how high the alt sits etc??
what extacly did you use to attach your alt besides the summit tensioner?
Old Dec 14, 2005 | 07:31 PM
  #53
pmpnavt's Avatar
Engine: L98 350
sure...here are some more pictures...ill take another pic of the whole setup from the front of the car. i do not have an intake on the engine yet...im still deciding how to go with it...but i hope to have made my choice before xmas this year.
the bracket on the back side of the alt is the original one that held the alternator to the exhaust manifold on the driver side...just took a lil "work on the bbq grill" to get it bent the right way
im working on polishing the bracket...so it just looks like bare metal ATM. if you need other pictures or part numbers ill help you out.
Old Dec 14, 2005 | 07:32 PM
  #54
pmpnavt's Avatar
Engine: L98 350
here is the alternator front view....please note that the exhaust wrap is not going to be held on with plastic zip ties
Old Dec 14, 2005 | 10:15 PM
  #55
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
LOVE that setup pmpnavt, very clean and very "custom shop" looking. i am loosing the P/S pump so i will only have the water pump and alt, tho i will probably go to a electric W/P, but still that looks hella clean, NICE
Old Dec 14, 2005 | 10:42 PM
  #56
pmpnavt's Avatar
Engine: L98 350
hey thanks i try to do what my skills allow me
ill post when the engine is done in a month or so
Old Dec 14, 2005 | 10:51 PM
  #57
where you at in chicago pmpnavt???
Old Dec 14, 2005 | 10:57 PM
  #58
pmpnavt's Avatar
Engine: L98 350
northern sub....
just south of lake geneva WI
its just easier to put chicago
Old Dec 15, 2005 | 01:07 AM
  #59
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
So how can it be adjusted when the bracing bar on the back doesn't let it move? I'm confused...
Old Dec 15, 2005 | 08:57 AM
  #60
pmpnavt's Avatar
Engine: L98 350
the side that is connected to the header is not shaped like an "o" its shaped like a "u"
if you have a tpi car take the brace off the back of your alt and that is the same one. all i did is heat it up and twist it in a vice a bit.
Old Dec 15, 2005 | 01:32 PM
  #61
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
damnit...i think i threw that bracket away awhile ago when i took it off!!!
Old Dec 15, 2005 | 03:20 PM
  #62
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Is that going to be enough contact patch on the waterpump?
Old Dec 15, 2005 | 04:09 PM
  #63
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
should be fine. ive got mine routed a different way but has just about the same contact and works great wet or dry.
Old Dec 15, 2005 | 07:26 PM
  #64
pmpnavt's Avatar
Engine: L98 350
i was going to just buy a bracket set for my alternator, but when i talked to the summit tech line and the march performance pulley tech line, they told me that it is not possible to put the alternator on the pass side of my car. for some reason i dont like being told that "you cant do that". i just makes me want to do it more...kinda like my gear drive and a 300 dur 550 lift cam on a computer controlled tpi 350 :P
Old Dec 17, 2005 | 11:06 PM
  #65
pmpnavt's Avatar
Engine: L98 350
here is the picture of where the alternator is compared to the rest of the engine. take care
evilstuie
Jan 9, 2020 08:29 PM
lt1z350
Aug 28, 2015 05:57 AM
mustangdmurder
Aug 21, 2015 07:17 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
