Combo Thoughts
Old Jan 15, 2005 | 12:03 AM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
Combo Thoughts
Need some thoughts from you guys on this setup
L98 block converted to 4 bolt
Eagle Cast Steel 383 crank
Eagle H beam 5.7" rods
Speed Pro Forged 383 pistons and rings
400 SBC Fluidamper
Stock Flexplate
Jegs 197cc heads 64cc
LT4 Hot Cam
Holley Stealth Ram
Comp Pro Magnum 1.6 RR
Built TH350 w/ 3000 Holeshot converter
Complete Spohn Suspension
Spohn Heavy Duty Driveshaft
3.70 gears
Mickey Thompson ET Streets
TNT wet kit 50-150hp
and dropping as much weight as possible
Just wondering what you guys thought this combo could do.
Old Jan 15, 2005 | 02:58 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Just a comment on those heads. They're $1200 assembled. You can get them from Canfield bare for $600 per pair. They are just the Canfield heads with Jeg's stamped on 'em.
Old Jan 15, 2005 | 08:39 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Your combination with the right tuning should be a solid 11 second car.
I was able to reduce some weight on my 86 by removing the A/C unit, aluminum heads, removed front sway bar(at track only), spare tire etc. Last time at the track I placed the car on the scale and it weighed 3325 lbs.
www.geocities.com/dzperf
Old Jan 15, 2005 | 08:08 PM
Car: 1988 GTA
Transmission: TH350
Yeah for weight reduction so far I've removed the AC, smog pump and all the other EGR stuff, rear seats, hatch shade, front swaybar, switched over to Weld Prostars with skinnies in the front, going to be switching over to racing seats up front this summer.
Where can you get the canifeld heads for that cheap?
Also, do you guys think the Hot Cam will be enough for this setup?
Old Jan 16, 2005 | 11:18 AM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
The LT4 Hotcam will be fine. Look at http://www.stealthram.com/hsrcars.html
You can see the combos that guys are running with the HSR and the times they are running. Mike Davis is running 11.73 with the LT4 Hotcam.
Bubbajones_ya
Jul 6, 2024 08:32 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
TheExaminer
Sep 28, 2015 02:28 PM
RedLeader289
Sep 23, 2015 06:50 AM
IROCZ1989
Sep 4, 2015 11:54 AM
