Plenum Vacuum Fitting Thread Size
Old Jan 20, 2005 | 12:54 AM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
Not sure anyone knows this, but I'm trying to find the size of the female threads for the two vacuum fittings on the rear of the plenum located on the passenger side. I had the plenum powdercoated and the shop got just enough powdercoat into the threads so that I can't thread one of the fittings in. I'd like to buy only the correct taps to clean the threads. I'm trying to save some cash by not buying an entire tap and die set. While I'm at it, I'm also wondering about the thread size for the pcv connection on the driver side as well. If nobody knows this info, can somebody point me in the right direction on a way to find this info? I've already searched the threads. Thanks in advance.
Old Jan 23, 2005 | 03:27 PM
Vader's Avatar
On my '86, the brake booster hose fitting is 1/4" NPT. I'm not sure of the other fitting.
Old Jan 23, 2005 | 04:29 PM
onebinky's Avatar
I'm about 95% sure the pcv fitting is 1/4 npt as well. If it's not that, it's a 3/8 npt, but I'm pretty sure it's 1/4 npt
Old Feb 12, 2005 | 09:39 PM
Engine: 5.7L TPI
I want to thank everyone who responded to my post. The fittings were 1/4" NPT. I found the tap I needed at OSH for around 7 bones. If I didn't have help from you guys I could've totally ran the wrong style tap through and ruined the plenum. This is just another example of how valuable these boards are. Thanks again. One last thing: I didn't get a chance to make my donation to thirdgen.org yet because times are tight (I just had a baby), so can anyone give me Dirk's email address so I can give something though Paypal?
Old Feb 12, 2005 | 11:09 PM
onebinky's Avatar
glad to help, thats what the boards are here for
That reminds me, I still have to make a donation too...
toronto formula
Nov 10, 2015 06:17 AM
bamaboy0323
Sep 3, 2015 06:07 AM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
