i gotta problem
Old Jan 22, 2005 | 07:34 PM
MRIROC's Avatar
Car: 87 IROC
Engine: 355TPI SUPERRAM
i gotta problem
when i start my car,my fuel pressure jumps right to 90 psi,and stays there. now while im driving, if i smash the gas the fuel pressure goes to 45 psi.when i shut the car off it will take about 20-30 minutes to drain down.i already dissconnected the return line at the rail to see if theres a restriction in the line but it still stays at 90 psi when running.hope this aint to confusing
Old Jan 23, 2005 | 10:05 AM
TPIJeep's Avatar
Engine: 7.4 L of Small Block Fun...
seems to me your FPR is stuck... and if its really 90psi your going to toast your fuel pump shortly...
The reason for the drop to 45psi under WOT is the fuel pump can't supply enough fuel at WOT @ 90 PSI.
Old Jan 23, 2005 | 05:02 PM
onebinky's Avatar
Yep, either the regulator is stuck shut or clogged, or you have a restriction in the line before the regulator.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
