TPI problem
Old Feb 6, 2005 | 09:41 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
TPI problem (bad idle) and (cleaning IAC)
I am having a problem with my TPI it is a 1985 Trans Am 305.
When cold and I start it the idle will fluctuate and try and stall on me. (badly)
When warm and in closed loop the idle is between 700 and 900 RPM. When you drive it it will hesitate when you accelerate. (alot)
Heres what the computer reads:
Integrator: 140
O2 crosscounts: Fluctuates between 1 and 4
O2 sensor M/V: fluctuates too much to say its High then low then high the low ect...
ESC: 0 (that is all the computer says), not sure what it means
Closed Loop
Block Learn 158
The computer says it is running rich.
What I have done so far:
New: MAF sensor, O2 sensor, Full Tune up (wont list), Fuel Filter, Electronic Spark Control Module, Distributor spark module,did the timing and cleaned the throttle body(including the IAC). Used a propane torch to try and find a vaccum leak (none found) Ichecked if it is the correct computer in the car ( it is)
Thanks in advance for all the help.
Old Feb 7, 2005 | 06:47 AM
TPI-454's Avatar
Car: 1989 Trans-Am
Engine: 454-Motown SBC w/HSR
Transmission: 6-Speed
Re: TPI problem
Originally posted by 1985WS6transam
When cold and I start it the idle will fluctuate and try and stall on me. When warm and in closed loop the idle is between 900 and 1500 RPM. When you drive it it will hesitate when you accelerate.
Before I swapped over to the 454, my 350 gave me the exact symptoms... believe it or not, it turned out to be the spark plugs. I forgot to gap them correctly.
I'd also check for a vacuum leak if I were you. Hesitation under acceleration, usually goes hand and hand with a vacuum leak.
...and cleaned the throttle body.
This would include the IAC as well, right?
Old Feb 7, 2005 | 06:20 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Yep, when reading your post a vacuum leak was the first thing that popped in my mind. Allen
Old Feb 7, 2005 | 10:42 PM
91Z28CAMARO32's Avatar
Car: 91 Z28 CAMARO
Engine: 383 STROKER TPI
Transmission: TH-700-R4
my car did the same thing so i put a new knock sensor in and it cleaned right up
Old Feb 10, 2005 | 02:12 PM
Engine: 388 Carb
Axle/Gears: 4.10
New Info
My manifold pressure when cold is between 10-12 psi and idles about 500 rpm. The car will try and die unless gas is given to it.
When warm the car idles at about 700 rpm and has between 18-20 psi of pressure. Still hesitates badly.
The fuel pressure is at 38 psi
2 codes come up MAF to low, so i replaced the MAF and still have a code as well as ESC replaced that too and still have a code
I will get the code numbers by tues night
Old Feb 16, 2005 | 02:17 PM
Engine: 388 Carb
Axle/Gears: 4.10
I took off the throttle body and the IAC motor and tryed cleaning both, when i put it back on no change, could the IAC motor be bad and i dont know it?? Is it true that the only 3 sensors used for open loop are IAC CTS and TPS? my main concern is fixing the cold problem, it is so hard to work on when it will die in open loop.
Old Mar 26, 2005 | 02:33 PM
Engine: 388 Carb
Axle/Gears: 4.10
How did you know it was the knock sensor or was it just a lucky guess?
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
jbd1969
Aug 17, 2015 07:06 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
