anyone have results for a 52mm tb?
Old Feb 11, 2005 | 08:50 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
does anybody have any track or horsepower numbers after switching to a 52mm throttle body?
Old Feb 11, 2005 | 09:18 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
i really didnt notice if the 52mm TB helped on its own because i installed other mods at the same time. It sure didnt hurt.
Old Feb 12, 2005 | 12:45 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Hi Matt
Those are darned good times for the mods listed. I also have an 1989 Trans Am with Trickflow heads and ZZ9 cam to meet the times you have posted. Anyways I'm running a 52MM throttle body and I feel it has helped. With the 700R4 transmission I'm turning to 6000rpm in first gear for the 1-2 shift point and I feel the engine needs all the air it can get. Allen
1/4 mile, 13.30 and 103.59 last time out. Looking for high 12's next run.
Old Feb 12, 2005 | 01:20 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
i just installed the throttle body. can't really tell if it did anything. im hoping to possibly go 122.70's to 12.80's on the stock heads, cam, intake runners, and torque converter before i install the tpis big mouth kit with afr heads and zz409 cam.
Old Feb 12, 2005 | 01:43 PM
Car: 89 Formula 350
yeah nice times. I've been seeing how fast I can go with external engine boltons. Best Ihave managed is a 13.21@104.6 Mods listed in sig. Anyway would be cool to see someone break into the 12's w/just boltons. good luck with it.
Old Feb 12, 2005 | 03:32 PM
Damon's Avatar
I agree- nice times for the mods. Best I could ever get out of a basically stock L-98 was bottom basement 13s, throwing every bolt-on part at it I could lay my hands on. I had SLP runners on mine and a ported upper plenum, though.
Old Feb 12, 2005 | 03:48 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Sorry Matt, im calling BS on those times you posted...
stock heads, stock intake, stock runners... hypertec chip?? stock air cleaner, stock cam..
come on now.. you see what mods the other guys have and are running the same times... theres no way you are running that, especially with a hypertec chip.. and stock stop end..
sorry, not buying that one.
Old Feb 12, 2005 | 04:34 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
no bs. i don't lie. working on getting u pictures of my 120 timeslips. im at maryland international raceway every friday night, come and see.
Old Feb 12, 2005 | 05:32 PM
nismo2491's Avatar
i'm a friend of gta_matt's he doesn't know how to post pics really: here's timeslips
and motor
not ganging up on you all, just helping him out. if those don't work they are on my photobucket account here's links if I'm over my bandwith:
http://img.photobucket.com/albums/v2...1/DSC00131.jpg
http://img.photobucket.com/albums/v2...1/DSC00130.jpg
http://<br /> http://img.photobucke...1/DSC00132.jpg
KEvin
Old Feb 12, 2005 | 05:33 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
http://photobucket.com/albums/v243/n...t=DSC00131.jpg
http://photobucket.com/albums/v243/n...t=DSC00132.jpg
http://photobucket.com/albums/v243/n...t=DSC00130.jpg
pictures of motor and time slips
Old Feb 12, 2005 | 06:52 PM
91 z28 350's Avatar
Car: 91 Z28
Thats crazy your cars a freak. you have all the smog and a/c hooked up ?
Old Feb 12, 2005 | 08:21 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
air pump is untouched and ac blows icecubes. i have gutted the catalytic converters but it ran 13.50 through the stock manifolds and converters.
Old Feb 12, 2005 | 09:32 PM
brutalform's Avatar
Re: anyone have results for a 52mm tb?
Just clean up your plenum directly behind the T/B, and you will almost get the same flow as a larger unit for FREE, +labor.
Old Feb 13, 2005 | 02:39 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
well i stand correct and i am not afraid to admit im wrong. and i also appologize.
your car is a freak.. funny this i just grabbed my time slip.. and we are exactly the same to the 8th mile.. then for some reason i die off at only grab a 13.94 @98.89.. weird.. but your mph @ 82 and the 1/8th time are almost idential as mine.
damn those 3:23's
Old Feb 13, 2005 | 02:44 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
those times were with 3.23's. i just installed the 3.73's 2 weeks ago. the difference is much better then any other mod i have done. at the same time as the gears ive installed the sphon torque arm, LCA's and drag radials. it is MUCH faster now.
Old Feb 13, 2005 | 02:47 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
by the way, apology accepted. nobody believes what i have done, not even people who've seen me run.
Old Feb 14, 2005 | 02:31 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
gotta love the Factory Factory Freaks
Old Feb 14, 2005 | 11:36 PM
DON 88T/A's Avatar
At MIR you can get some decent #'s I've heard...75/80...diffrent story.
Old Feb 15, 2005 | 01:13 AM
OMINOUS_87's Avatar
Way to go, making a huge ASSCLOWN of yourself...
Old Feb 15, 2005 | 01:14 AM
OMINOUS_87's Avatar
I havent upgraded from the stocl 48mm with an airfoil to offer you any results.
Bu I am running the times in sig with the stocker, 48mm that is,
Old Feb 15, 2005 | 01:27 AM
vladicore's Avatar
Car: 67 camaro ( project )
Engine: 6.7 408 n a snail
Transmission: 4l80 - stalled
Axle/Gears: 3.25 - narrowd tci kit 9 inch
i have a 91 z28 l98 that has stock bottom end and heads, accel superram intake, slp runners ported plenum, air foild knn w/ mod box, stock tb, no smog pump, no cats, accel wires and ac delco plugs, w/ a built 700 and a posi 3.23 gears. and i wont even post my reaction and 60ft times because they are that terrible and i ran a 13.7. my buddy w/ alot more respectable reaction ran a 13.2 in memphis motorsports park on a hot humid day.
so i can believe someone is running low 13's or high 12/s w/ bolt ons but i also agree you car is a freak! no other way @ it!
Old Feb 15, 2005 | 01:34 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Well,
hes puts ideas into my head that
my car can get there ..
motivates me to say the least.
you have a Speed density system correct?
maybe the MAF car requires more to achieve those ETs?
ill have slips of what I put out within the next month.
(cross dem fingers ))
highly unlikely event I even crack mid 14s
Old Feb 15, 2005 | 07:26 AM
brutalform's Avatar
Best times 2 1/2 years ago, with a ZZ-9 cam, trickflow heads, and S/D.....13.00s @ 108. Never broke in the 12s with my 350, but probably would have with my MPH. Oh yea, I had all the other stuff too!
I also hollowed out my cats, and picked up "zero" at the track.
Old Feb 15, 2005 | 11:15 AM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
Omnius87, you've been reported for violating board policy..
have a great day!!
Old Feb 15, 2005 | 11:43 AM
OMINOUS_87's Avatar
have a great day!!
For what, pointing out the obvious???
Old Feb 15, 2005 | 11:56 AM
tpi_roc's Avatar
Both of you are being rediculous.
Falcon50
Aug 22, 2020 03:26 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Thornburg
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
