accel superram ? inside
Old Feb 13, 2005 | 02:49 PM
vladicore's Avatar
Car: 67 camaro ( project )
Engine: 6.7 408 n a snail
Transmission: 4l80 - stalled
Axle/Gears: 3.25 - narrowd tci kit 9 inch
where can i get a new gasket set for an accel supperram? also need a throttle body gasket for a 58mm accel throttle body. also what gasket matches the intake for these? any help is appreciated
Old Feb 13, 2005 | 03:14 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
http://www.jegs.com/cgi-bin/ncommerc...19&prmenbr=361
part number 310-74195G
31.99
Old Feb 13, 2005 | 06:23 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
I would wait unit they fix the problem with the Superram gaskets.
For some reason they don't fit on the drivers side EGR it off slightly. This is the making of a vac leek waiting to happen. I have found this out thought the corvetteforum group.
Old Feb 14, 2005 | 12:01 AM
vladicore's Avatar
thanks for the links to jegs i dont know how i missed it befor. my setup is not emmisions legal so the egr gasket will be tossed anyways. i still cant seem to find an 58mm tb gasket though. i took the one off of an ol tuned port setup i had and it sticks out at least 4-5mm all the way inside the tb. that just cant happen in my setup she needs all the air she can get.
Old Feb 14, 2005 | 02:23 PM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
As for that Gasket issue, I found out the hard way with a huge vacuum leak. Easy fix is to get some gasket paper and trace it and cut your own. Took a half hour with a exacto knife and my dremmel tool to clean up the port holes.
Old Feb 14, 2005 | 03:13 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
The 58 mm gasket comes with the set im pretty sure. I buy mine from LPE.
Old Feb 14, 2005 | 03:45 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Me too (from LPE), and yes, it does.
Old Feb 14, 2005 | 03:56 PM
Car: 1987 Iroc-z
I'm sure if you get a 4 dollar stock one from autozone you could work some magic with a dremmel tool with a sanding wheel. I think stock is 52mm even though stock throttle bodies where 48mm.
Old Feb 14, 2005 | 06:46 PM
vladicore's Avatar
so u are saying the 58mm gasket for the tb goes in the jegs $31 dollor kit? i dont see it in the pic?
Old Feb 14, 2005 | 07:45 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Have you have visited here- LPE EFI gaskets?
The 58mm throttle body base gasket lists for $2.25. All I can find on Summit/Jeg's is part number 74190G that cost $17!
I'd give Summit, Jeg's, or LPE a call.
Old Feb 14, 2005 | 09:11 PM
Jade Grey's Avatar
Engine: 305TPI
I hate replying to my own reply but...
I totally missed this from the link I listed above
Kit shown is the SuperRam Plenum runner kit that includes the throttle body gaskets.
That kit, LN-0010SR, lists for $23.95 at LPE.
I think the $2.25 piece is the gasket between the throttle body and the IAC housing. I wanted to correct my mistake. Sorry.
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
Pac J
May 17, 2020 10:44 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
KO1
16
Oct 15, 2015 05:00 PM
