Question about gear drive and TPI???
I have a stock 1987 305 TPI that I would like to put a good quality gear drive in for the "sound appeal". The motor will remain stock except breathing and exhaust improvement. MY QUESTIONS: Will the gear drive mess with the antiknock sensor and cause it to signal the computer to retard the spark (as if the car were detonating) ?????? I keep thinking I read an article in a magazine or on this forum warning of this. DOES ANYONE HAVE ANY HANDS ON EXPERIENCE WITH THIS ON A TPI MOTOR??? I would prefer first hand experience over theory. THANK YOU in advance!!!!!!!!!!!!!!!
Guest
Posts: n/a
Could try a search, but to answer your question...
Probably the only thing out there right now is the same as always, Pete Jackson 'quiet' gear drive. Its not that quiet IMO. It also wont mess with the knock sensor, just make sure you read and follow the instructions.
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
from everything ive heard, gear drives do screw with the knock sensors. i don't know if the quiet ones will, but then you would be defeating the whole purpose of getting a gear drive....
Guest
Posts: n/a
I'm running one, have been for 10 years. It does not mess with the knock sensor. Do a search before you speak, its been beat to death here by owners of them. The 'i heard' thirdhand stuff has never materialized, its another myth that continues to propogate.
And it is anything but quiet. Its about as quiet as putting your face in front of an operating fog horn.
http://home.earthlink.net/~wtomfoster/gp.wav
Quiet? Not even. Thats a blowmaster with no cats out the exhaust.
Engine: L98/383
Axle/Gears: 9"
oh well, definitely not the first or last time i've been wrong. i thought about going to gear drive but was turned off by all the talk from the manufacturers about knock sensors.
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
You can always put it in and see if it messes with the sensor. If it does you can always disable it in the chip.
No questions are dumb, everyone needs to learn sooner or later. It replaces the chain and sprockets for more accurate crank to cam timing.
I love the sound they make
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Gear drives do not sound like superchargers.....if you heard the two of them side by side, you would know what I mean.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Car: 1985 IROC-Z
Originally posted by Bri3212
406TPI. I have been fooled a few times.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I don't know much about gear drives...is this what I would need? (5.7 TPI)
http://store.summitracing.com/defaul...h.asp&x=25&y=8
I've never heard one before. Are they worth installing?
Car: 1985 IROC-Z
1992rs/ss
Jan 31, 2025 05:10 PM
Iroc8t8
Aug 26, 2015 08:14 AM
