Factory Heads
Old Feb 18, 2005 | 09:46 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Factory Heads
Can anyone tell me the specs on the 1989 factory L98 (non-corvette) heads?
For example, 64cc combustion chambers / 180cc intake runners?
I assume they are not 2.02" int valves?
I am looking at getting new heads and would like to know this info so I can estimate my compression ratio.
Thank you!
Old Feb 19, 2005 | 10:03 AM
DeepSouth_454's Avatar
The 64cc for an iron L98 head is all you need to calculate the compression ratio.
Old Feb 19, 2005 | 10:11 AM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Valves are 1.94 In and 1.50 Ex. The chamber is 64cc and I think the runner is somewhere in the 160-170cc range but I'm not 100% sure on the runner size.
All you'll need to know for the compression ratio, atleast from the head, is the combustion chamber size.
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
MoJoe
Sep 24, 2015 09:12 PM
eddie jr
Aug 25, 2015 06:52 PM
fonzie85
Aug 13, 2015 11:50 AM
