Interesting Head Article
Old Feb 19, 2005 | 06:09 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
While researching cylinder heads, I came across this article and thought I would share it...
http://herning.crosswinds.net/projects/350heads.html
Hope this helps.
Old Feb 20, 2005 | 11:58 AM
Vader's Avatar
Yes. That original article was available on the CHP site for a long time. http://www.chevyhiperformance.com/techarticles/41598/
There are other useful ones as well:
http://users.erols.com/srweiss/tablehdc.htm
Old Feb 20, 2005 | 04:27 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Re: Interesting Head Article
Hope this helps.
Hey formula? How do you like those 24lb accel injectors?
Old Feb 20, 2005 | 05:09 PM
The 24# were great at first... but its been about 2 years and now I have a miss.
I believe it is either a bad injector or a valve.
On the positive side, the Accel's were fairly cheap and easy to install - especially considering that I had never swapped injectors before.
Old Feb 20, 2005 | 05:59 PM
vortec77's Avatar
Car: 86 T/A
Thanks, for the Info. I have the accel 24# injectors now, I just havent fired the motor up yet. Just wondering what i have to look foward to.
specialized
Jun 18, 2022 09:26 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Thirdgen89GTA
Aug 25, 2015 06:40 PM
89mulletbird
Aug 12, 2015 07:08 PM
