Stealth Ram Intake
Old Feb 22, 2005 | 03:55 PM
88CAMARO--3's Avatar
Car: 88 Camaro <--hope to get a new one soon!
Stealth Ram Intake
Im looking into getting maybe a stealth ram intake but am wonding if it would pass emisions with it? Also should i convert it to a 383 stroker before i get the intake or get the intake first. also is there any clearance issues with it? thanks
Old Feb 22, 2005 | 04:29 PM
rsn932's Avatar
the stealth ram is not emissions legal as it has no provision for EGR. you might have to cut out a little bit of the bracing on the bottom of your hood.
Old Feb 22, 2005 | 05:27 PM
if its not emisions legal how would i renew my plates in WI what do you all do?
Old Feb 22, 2005 | 05:47 PM
Chrome's Avatar
Car: 92' RS Camaro
Depends on the rules in WI. If they are tough there, then you better be putting something that is compliant on; not the Stealthram. If laws are tough there look into the SuperRam, I believe it is 50 state legal.
Old Feb 22, 2005 | 05:58 PM
anondude13's Avatar
You can get external EGR, or tune your car to pass the sniffer without EGR. And since you have a camaro, it will fit under your hood without modification.
Old Feb 26, 2005 | 12:35 AM
qwik86iroc's Avatar
Car: Guess!
Engine: 350 Stealth Ram, Supercharged
Transmission: 700R4 / 3.73
The stealth Ram is agood choice for performance, and it will clear the stock hood. The only thing I had to do was spin the clamp that seals the intake boot to the throttle body over 180 Degrees. It has problems fitting the Vette not the Camaro. Mine made a serious difference in the top end. I bought the bare setup with Intake and fuel rails only. But keep in mind it's not just bolt on.
Old Feb 26, 2005 | 04:11 PM
big black bird's Avatar
Car: 1989 transam
Engine: 350 hsr trickflow twisted wedge g2 comp cam 490 lift haltech e6gm ,33lbs bosch injectors
Transmission: t700
i wish you guys would have told me about spinning the clamp that is on the intake bellow as i didnt and by not doing it i have a nice dent in my hood i was ultra careful not to slip with the angle grinder and cut the hood and then this happend i went along with the impression that i only needed to cut the structural support of my firebird hood so anyone out there make sure to spin the clamp around. also you cannot use the tpi k&n filter that clamps onto the throttle body clearance issues again
Old Feb 26, 2005 | 04:46 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Yeah, well I guess that I will be first in line to take responsibility for you being stupid...because after all, I am half a world away and didn't work on your car. Try actually measuring some clearances and NOT taking advice from a website as gospel for your car.
To be fair to my brethren at Thirdgen though, the topic of hood clearance for the Stealth Ram has been brought up since the beginning and that IS covered on this website, if you did a search.
Old Feb 27, 2005 | 10:04 PM
Car: 1989 transam
Transmission: t700
relax my friend im not holding anyone responsible for my f--k up done many of them when it comes to cars as for the site i really rate it as it keeps alive the enthusiasm for the dying american third generation firebird , camaro which correct me if im wrong are being replaced by the australian holden monaro
Old Feb 28, 2005 | 01:24 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
so if u use external egr than it still wont pass emissions
Old Feb 28, 2005 | 07:13 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
If your motor is tuned correctly and Wisconsin does not do an under hood visual you can pass an emissions test. I passed the Ohio 25 mph roller test with my 406 solid roller Miniram motor.
It will take some tuning and a wideband O2 to get the fuel ratios right.
www.geocities.com/dzperf
Old Feb 28, 2005 | 11:29 AM
Engine: LS3
Transmission: 6L80E
I understand where you are coming from now. I am too used to seeing kids blame people on this site for their own ignorance, inexperience and stupidity. Obviously, you are not one of them
As for the emissions requirements, unless you are running in an area without emissions or with basic requirements, you are limited in options...
Old Feb 28, 2005 | 10:21 PM
Car: 1989 transam
Transmission: t700
at 32 yrs of age hardly a kid but i always seem to run into trouble when im doing mods never ending story once you start but really holley should have designed a manifold that fitted under a thid gen firebird also should have taken consideration for the people with 89-92 throttle bodies my throttle lever is just clearing the fuel rail fitting had to grind the fitting to clear hopefully edelbrock will get it right with there product
Old Mar 1, 2005 | 01:04 AM
Engine: LS3
Transmission: 6L80E
I agree, Holley should have designed it better...it irritated me when I installed it on my GTA too
Old Mar 3, 2005 | 11:12 AM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
Move out of the Milwaukee area.... We don't have any testing in Madison, lol.
Do you have any family outside of the Milwaukee area? I'm sure you could find a way to renew your plates that way, but like someone else noted, you could focus on doing the best tune that you can so that it will pass the sniffer... Do they do visual inspections over there?
Old Mar 3, 2005 | 04:01 PM
well i live in washington county outside of milwaukee but not quite to the point were there is no emissions. (another 15 miles and i wouldn't have to worry) Ill prolly go to tuning method and see how it does once i get it which might not be for i while yet. thanks for the help
Stangski09
Nov 14, 2015 01:27 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
R3500
Sep 8, 2015 10:12 PM
09ave
Sep 7, 2015 06:03 PM
