SVO -vs- Chevy Fuel Injector O-Rings?
Old Feb 22, 2005 | 04:11 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
For those who are using Ford SVO Fuel Injectors:
Did you use the O-rings that came on the SVO injectors, or did you replace them with the larger diameter stock Chevy injector O-rings?
Do they leak with the SVO O-rings?
Where's a good place to buy the Chevy O-Rings?
Old Feb 22, 2005 | 06:42 PM
Ed 2001 SS's Avatar
Re: SVO -vs- Chevy Fuel Injector O-Rings?
I used Chevy O rings on my SVO injectors. IIRC the O Rings were included in the Fel Pro lower intake manifold kit.
Old Feb 22, 2005 | 07:07 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I bought 24 #/hr FMS (AKA, SVO) for my '87 IROCZ. I used the injectors right out of the box, and never had a fuel leak. Grease the orings very well, and slowly squeeze them into the fuel rail first AND use the clip. The clip will position the top of the injectors into the fuel rail. Then just (and very carefully) get all 8 injectors to seat in the holes in the intake.
Done deal.
Old Feb 22, 2005 | 09:04 PM
Guest
Guest
Posts: n/a
I used the ones that came on the injectors, the OD of the o-ring wasnt any different. Better to check that and make sure though, just to be safe. I heard that early versions (many years ago) had smaller o-rings that didnt work.
Old Feb 23, 2005 | 10:03 PM
ChevelleFan's Avatar
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
I bought a set of O-rings from my local Chevy dealer under GM part # 17113544. Should have 16 o-rings in it. I have yet to install my injectors, though.
I think they were about $15 + tax.
-Dave
Old Feb 23, 2005 | 11:13 PM
mnorton's Avatar
Engine: 305 LB9 TPI
Thanks everyone!
Old Feb 24, 2005 | 02:03 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I used the chevy o-rings in mine. They were slightly larger you could feel it when you put the parts together. I had a set of them laying around so I pulled them out to compare.
That was 4-5 years ago when I put the Motor in.
Old Feb 24, 2005 | 09:25 PM
Vader's Avatar
Interesting. I know the older Ford rings were of a smaller cross section than GM. I wonder if Fjord finally "got on board." Oh, nevermind - They still make the tinkertoy, er, Romeo engine.
bryan623
Mar 22, 2021 06:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bamaboy0323
Sep 3, 2015 06:07 AM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
