Exturdehone stock or buy aftermarket intake
Old Feb 23, 2005 | 01:23 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
Trying to make my mind up. It cost $375 to extrude a stock intake, the same amount of money a Edelbrock intake cost. If I buy the edelbrock intake,I can use the porting kit from Eastwood Company that I purchesed awhile back. I've never tried to port anything...so I won't take too much material off the edelbrock intake. Any ideas.
Old Feb 23, 2005 | 02:51 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Keyword here, is "supposedly" an extrude honed lower base will move some serious air. Equal to or better than the aftermarkets. I do not have flow numbers to back it up with, just what I have heard over the years.(I'm talking back to highschool days 10+ yrs ago even)
The stock intake has a lot of room left for porting and cleaning it up, especially in regards to casting flash. I did this to my leftover intake from my Formula and it came out quite nicely. Plan on using the ported stocker with modified stock runners on my stock 91 350 gta when i do the valve stem seals and reseal the intake. If someone tells u its a waste, check out the pile of aluminum you have left over when your done.
Do a search for tpi intakes and extruse honing and the like and you should find more than the info you would ever need on the subject.
Also GMHTP did an article and flow tested various tpi offerings, like edelbrock, stock, accel, etc runner and intakes. Searching should net you that info here as well. It was discussed quite a bit on the boards
I think all the aftermarket tpi bases are about 150$ overpriced. I own one for vortec heads, it runs u 400$. There is also the used alternative like the classifieds.
If u decide to go the extrude hone route or any of the others, u can see if there are any current group purchases going or find out how many people u need to start your own.
later
Jeremy
Old Feb 23, 2005 | 03:15 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
How would you pressurize your poop enough to Exturdehone your intake? Mexican or Tai food??? ...and would you eat crushed walnut shells for the abrasive??? Ouch!
I don't see an advantage to Extrudehoning the intake other than on some aftermarket runners or something. The base and plenum are way to easy to do yourself if you already have the P&P kit from SA.
Old Feb 23, 2005 | 04:20 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Buy aftermarket now then later extrudehone it. I extrudehone my TPIS Big Mouth Base and my Super Ram Runners for $600. I just have to finish tuning the car to get the max perfomance.
Old Feb 24, 2005 | 02:22 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
If it were me i would buy the aftermarket and port it myself.
Ive also read that a ported stock base can flow as much as an unported aftermaket base.
But I think you can port the aftermarket even further. Thats what I did anyways.
Old Feb 24, 2005 | 06:42 PM
VincentZ28's Avatar
Mikeh, Have you race you car at the track? If so, what are the times?
Old Feb 25, 2005 | 05:48 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Not with this setup... I cant seem to keep a tranny in the car long enough. 3/4s are toast...The Motor is making good power now. After lots of problems and tuning!
Just have to get it to the ground. I have to spend the money and get a good tranny and rearend setup first.
Old Feb 25, 2005 | 07:44 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
practic porting the stocker. Buy a aftermarket and port it when you feel you can do it right and not mess it up.
Then have it e-honed as the last step.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Jake_92RS
Jan 28, 2020 10:37 PM
italiano67
Dec 11, 2016 09:21 AM
gta power
Aug 13, 2015 06:15 AM
