stock ignition.
Old Feb 24, 2005 | 11:26 PM
devilfish's Avatar
stock ignition.
Is the stock TPI HEI ignition ok to use abow 6000rpm? Or is it time to get a better system, if yes, what to get?
Old Feb 25, 2005 | 01:16 AM
Siggy's Avatar
Car: 1988 Camaro IROC LB9 F
Engine: 305 HO EFI
Transmission: TH700R4
Axle/Gears: GU5 LS 3.23
Stock ignition
Good question, I installed a Crane 6hi mainly because I got it cheap. All I've read and heard suggests that the HEI is very good and the real need for multiple spark is debatable, especially below 6000 rpm. Winter in Minnesota (if I stll lived there) I would certainly keep my Crane but your money may be better spent making sure the stock system is perfect....maybe add some good wire. When adding a hot ignition make sure the distributor module will handle the high switching current common to most CD ignitions. My stock module is holding using the Crane, 9mm wire and .065 plug gap.
Old Feb 25, 2005 | 03:42 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Get a better coil and you'll be fine. If you are running higher compression then you might want to get a different system, otherwise you don't really need it. I went with Crane Hi-6S for the higher spark energey, multiple sparks and the built in rev limiter.
Old Feb 25, 2005 | 08:17 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Would it help to put an aftermarket coil on a stock ignition?
LB9GTA
Old Feb 25, 2005 | 08:56 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
LB9GTA
It certainly wouldn't hurt to have an aftermarket coil, but there would be no noticable difference in power. I installed the Accel 300+ system on my car for the rev limiter and so I wouldn't have to worry after I do additional motorwork.
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
